Hi, I am getting ready to finally start putting the 400 chevy motor together for my 82 Z-28 and was wanting to know if someone out there can give an idea of the kind of hp and tq numbers I can expect. To start, it is a stock bore 400 with the 4.125" bore and the 400 crank with 3.750" stroke and 5.565" rods. The piston sits .025" in the hole with a .045" ROL head gaskets. The pistons come in with a -12.5cc dish and are Hyper Speed Pro's with moly rings. The heads are Dart Pro 1 Aluminum with 200cc intake runners and 64cc chamber and 2.02"/1.60" valves. The ports were only cleaned of flashing. The valve train is all Comp Cams with Beehive springs, hydraulic roller lifters, pushrods and Pro Magnum 1.6 Roller Rockers. The cam is a Trick Flow Retro Hydraulic roller unit with .563"/.574" lift and .230"/.234" @ .050" and 110 LSA. The intake is an air gap dual plane with a 770 Holley Vac carb and a set of Hedman shorty style headers.I am curiuos what this combo will have. Any ideas? Thanks in advance for any input from anyone.
