400 sb - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2010, 01:01 PM
400 sb
Which one is stronger the 4 bolt or 2 bolt main ?
Last edited by 68NovaSS; 09-28-2010 at 01:10 PM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 09-28-2010, 02:20 PM
techinspector1's Avatar
Wiki Edits: 326
Word on the street is that there is more material in the main saddle webbing (crankcase) in the 2-bolt block, making it more desireable for hot rodding. My feeling is that either one would be ok up to 500 hp if rpm's are kept at a reasonable limit. In my opinion, it's high engine speeds that will push the rotating assembly out of the webbing and cause you to run over the crank.
Old 09-28-2010, 04:53 PM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
If i have to here about this topic once more im going to freak out!
theres miles of posts about this and he just hit it on the head,
I personally build a 1970 4 bolt with ARP studs and had it internally balanced great machine work is the key to making this engines live.
Aluminum Corvette heads on SB 400 Tymer Engine 9 07-28-2008 12:00 PM
Good recipe for a 500 hp sb 400 chevy Littlered wagon Engine 25 01-31-2005 09:05 PM
400 sb? Silentlion_69 Hotrodders' Lounge 2 03-04-2004 05:18 PM
400 sb heads randyjrc123 Engine 13 02-04-2004 03:41 PM
Horesower for a 78 Chevy SB 400 sciaretta1250 Engine 3 11-14-2002 10:43 PM
