400 sb 4 bolt
Does it make the block stronger to plug up the water holes and redrill?
welcome Most all race builders tap the deck holes 1/2 NPT and insert a threaded hex plug that has a hole drilled in it. After installing, deck must be milled. The gaskets only have small holes in them anyway. Several companies supply these plugs. I guess it helps. Been done for years and years by the pros. |
Thanks that is what I was wanting to know, I am building a 400 sm block drag and street car, and had been told that it helps make the block stiffer. Do you know if it should be decked before or after the block is bored? |
read # 3,,,,,
FWIW, I haven't seen any gasket failures with 400 blocks that didn't have the plugs installed with properly prepared deck and head surfaces and good head installation techniques and good head gaskets. tom |
| 400 sb 4 bolt | gordsangel | Engine | 8 | 06-27-2006 03:00 PM |
| Sb Chevy 400 Uneven Feel 2800-3000 Rpm | slyshar2 | Hotrodding Basics | 5 | 11-18-2003 09:56 PM |
| 350 trans bolt to a 400 engine. | greg67 | Engine | 2 | 11-05-2003 11:27 PM |
| 400 SB v.s 350 SB | 70 nova | Engine | 8 | 02-22-2003 01:29 PM |
| What main cap girdle would you recommend for a chev 400 with a 2 bolt main | stonedchihuahua | Engine | 19 | 01-05-2003 05:31 AM |
