400 sb 509 block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2012, 06:33 PM
400 sb 509 block
I have a 509 block with block number 3951509. How do I tell if it is a 2bt or 4bt seeing how they were both made under that number. It has 4 bolts but it has had alot of machine work. not sure if cap are aftermarked or not. Outter bolt are bolted at an angle. I have seen splayed cap but am not sure if they are an older style.
Old 06-29-2012, 08:30 PM
BOBCRMAN@aol.com's Avatar
If it has splayed caps. It most likely was a two bolt converted. Why the concern?? A good block either way..
Old 06-30-2012, 09:27 AM
Agreed. Good block.
Splayed-bolt caps are far prefered for a strong 400SB. "Straight" bolts take material from an already weak area. Splayed bolts tie in to the "V".
As with all modifications like this, quality machine work is paramount in making the engine "live". Measure it closely. If properly done, can easily support 600 HP.
Jim
Old 06-30-2012, 12:22 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X3 you have a good one in that block. JMO i am running a 408 with a stroker kit and i love it never had and problems yet.
Cole
509 on block 75chev4x4 Hotrodding Basics 3 02-06-2011 03:31 AM
509 BBC 69 camaro, its all about the engine baby! Quarter mile killer Hotrodding Basics 12 10-28-2003 01:40 PM
509 BBC 69 camaro, its all the engine baby! Quarter mile killer Hotrodding Basics 2 10-27-2003 07:52 PM
509 BBC 69 camaro, its all about the engine, baby! Quarter mile killer Engine 10 10-25-2003 10:26 PM
396 Big block v.s. 400 small block Adrenaline_Fiend Engine 13 04-12-2003 04:14 PM
