400 sb heads
Wouls a set of 624's 1.94+1.50 make a 400 "weak" or what heads would be recomended for the street. looking for less than about 500$
Re: 400 sb heads
400 heads
What price will I be looking at for a good set of heads that are ready for install. I definately do not want a set that is crack prone.
what about the 461's are these the double hump heads? and are they any better than the 441, 493, 993's?
The 461, or any other "double hump" type casting are superior to the open chamber heads in terms of combustion efficiency. The compact chamber of the 461,462,291,186,492 and 041 head will yield more power, all other factors being equal than a comparable open chamber type head. Generally speaking, a good 20 horsepower over it's smogged out counterpart.
The bad part, as far as your 400 is concerned, is that if you use the early 64 CC heads on your 400, you will push the compression ratio beyond the realm of pump gasoline. You will have to use a seriously dished piston to maintain a streetable compression ratio. |
So what heads should I use where I do not have to use jet fuel..remember I want this for the street and I will be putting it in a restored short bed 67-72 truck. Should I stick to a 76cc head? or again what head should I use for this progect within reason...
This is just project and will not be used for racing by any means. Just a fun engine in a restored vehicle. Whith that in mind if I used a set of 462's or large chamber heads will I be able to use pump fuel? Last edited by randyjrc123; 02-03-2004 at 07:07 AM. |
Aftermarket heads are almost always the way to go. |
Leading someone to believe that you can run 91 octane fuel with a true 11.0:1 compression ratio is probably unwise. Maybe by some freakish combination, you are doing it, but most people will experience engine destroying detonation problems with this much compression on pump fuel. Of course, this has been discussed in depth in many, many threads and probably should not be rehashed in this particular thread.
Many of the 461 style heads that came with 1.94"/1.50" valves have chambers that measure around 60cc's or less.
I know I've said this before, but it's a good idea to take new heads to a machine shop to have them checked out. More often than not they need valve work and resurfacing. |
