Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 sbc
Thread: 400 sbc
Old 04-02-2002, 04:59 PM
Tom Tom is offline
change the rods to 5.7s the engine will last longer. check the rod bolt clearance if you do. hard block is good but only a partial fill and beef your cooling system.if you change cyl heads make sure you have the steam holes drilled
