Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 sbc
Thread: 400 sbc
  #16 (permalink)
Old 07-21-2012, 11:20 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by vinniekq2 View Post
just looked up your cam.107 intake angle/117 exhaust, extra 10 degrees exhaust. That 400 can use all of that cam.If its not damaged and the carb is the problem I wouldnt rush out to buy a new one yet.dial in what you have before pulling the grille on your truck.You could advance it 2 degrees if bottom end is low out put.I cant see it though
When he corrects the distributor advance curve he will have no lack of low end torque or throttle response.
As long as he did not fubar the cam install its fine as is.
Correcting the engine compression ratio is not that hard on this motor
with the dished pistons. Its not an issue to "driveability" or idleing etc
But will add power by correct ing the true compression ratio.
