400" SBC - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-13-2010, 05:33 PM
my87Z's Avatar
Veteran/Firefighter-EMT-I CRT
i would say that the rebuilding the 406 you have would be a better idea, or actually just freshin it up with new rings, bearings, hone the cylinders, then buy a better set of heads, carb, headers, and cam. and you could easily be above 450, it should be easy to hit 500+
  #17 (permalink)
Old 06-13-2010, 05:41 PM
4bnbad
PAW offers 426" block and all pieces for $3195.00
I wonder if a 426" could survive very long has a SCAT ROTATING ASSEMBLY
call the super gorilla motor on line I've bought many many parts from these guys
good place to do business.
  #18 (permalink)
Old 06-13-2010, 05:50 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Originally Posted by 4BNBAD
But I don't want to be
scattering parts on the saddle road racing a 16 year old squirrel in a Honda civic
w/coffee can exhaust tip.
I've driven on the saddle road. Worst road I was ever on except the road to the prison, it's the all time worst. Don't see how you can race on the saddle road, about 20 mph is all I wanted to do. There are some really crummy roads on the big island. Why don't you citizens light a fire under the legislature and get some decent roads built there?
  #19 (permalink)
Old 06-13-2010, 07:17 PM
4bnbad
saddle road all paved and widened to 4 lanes
Straightened out curves very nice place there is a real nice 1/4 " mile atrip right near airport in Hilo, Like the 60's
  #20 (permalink)
Old 06-14-2010, 01:10 AM
DoubleVision's Avatar
The 4L60E will only work if you buy a aftermarket computer command for it and they aren`t cheap. If you go the 700R4 route some parts are going to need beefed to handle the power output. Then you have to decide if you want to keep torque converter lock up or not as well as other odds and ends.
You`ll need a heavy duty aftermarket tranny cooler to keep it alive as heat is the number 1 killer of automatics.
  #21 (permalink)
Old 06-14-2010, 12:31 PM
4bnbad
I installed a heavy built 350 & 700R-4 in a 4x4 Toyota Land Cruiser the 4 door wagon version, used 411 diffs it came from factory with I had 700 built by a performance trans shop did use external oil cooler never any problems the 6 cylinder these came with are real dogs 18 wheelers passing me going through the mountains w/ 6
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 07:29 PM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
oil drain on SBC heads TerroRx7 Engine 7 03-17-2005 02:12 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 03:44 PM
