400 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2006, 02:00 PM
monte mike's Avatar
400 sbc
hello i bought a 400 sbc the code on the back is 330817 this just tells me that yes it is a 400 but from 1973-1980 i would like to know more it also have a number on the front of to13LS i cant seem to find this any on he back of the motor their is a T5 and A6/76 and also a conv1 and in the flywheel area is a Lh1 any help in the matter would bet great thanks.
Old 10-01-2006, 02:14 PM
nitro_baller4692's Avatar
floppers forever
http://www.nastyz28.com/sbchevy/sblock.html#casting
try this site
E.T. divided by $ spent= Speed
On the stamping pad in back of the altenator there is usually a 3 letter code like TMC or CMJ or something.You can look that up in an old chiltons and it will tell you what model and year cars had that code.
But more importantly there is a way to tell(not sure on 400)the nickel content of the block.On a 350 there will be an 010 or 020 under the timing cover.On a 400 I think its the last three digits of the block #(in your case 817)but I'm not positive.
Old 10-01-2006, 06:45 PM
monte mike's Avatar
hello
this is what is behind the alt to13 ls o cant seem to find it any were i look
Old 10-02-2006, 07:02 AM
DoubleVision's Avatar
Your date code represents A= January 6 -6th -76- 1976
Old 10-03-2006, 08:08 AM
monte mike's Avatar
thanks for the info
is their any way to find out the horse power buy these numbers
Old 10-03-2006, 09:09 AM
Can you describe the engine? Is it stock? Are you going to leave it stock? What kind of carb does it have? Mid-70's SBC 400's aren't rated for a lot of horsepower, maybe from about 165 to 240 depending on the configuration, but they are long on torque.
Old 10-03-2006, 09:56 PM
monte mike's Avatar
hi
i bought it from a guy who bought it from gm it was acreat motor and it was in a van with a th400 trans also so they only thing i have found out for sure is that it is a 1976 but as far as what is in side i have no idea not being a motor head i thought that all the motor codes on the block would tell but i cant find them.
427 sbc out of a 400 camaro409 Engine 23 08-02-2009 09:25 AM
sbc 400 81camprj Introduce Yourself 4 02-15-2007 10:25 AM
SBC 400 shim head gasket sb72elcamino350 Engine 4 06-28-2004 07:47 AM
My sbc 400 build up, please review Guitar Charlie Engine 13 06-17-2004 08:06 AM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 03:44 PM
