Hotrodders Bulletin Board
#1
400 sbc balancing problem
Folks,
How do you balance a 400 sbc? I think I need to replace the crank shaft. If I bring the crankshaft, harmonic balancer and flex plate to a machinist, can he balance the crankshaft for me? I look forward to your response. Thank you. Last edited by Tufel Hunden : 03-26-2008 at 05:29 PM. |
#2
re: 400 sbc balancing problem
Take it to a machinist who does balancing, and have the entire rotating assembly done, rods, pistons, crank, flywheel, balancer. And next time you install in your 400, make sure the bolt holding the balancer is torqued to spec with a drop of lock tite.
#3
Thank you brother, that's what I'll do.
#4
The 400 sbc is externally balanced, so it requires a counter weighted balancer and flywheel. it is possible to put a neutral balance on the 400 crank, but it requires drilling large holes in the crank weights and filling them with a heavy metal. If you don't want to spend the extra money making a neutral balanced 400 crank, you can still get your 400 balanced better at the machine shop, using the stock counter weighted balancer and flywheel.
#5
I wonder what it would cost approx? to have the crankshaft neutral balanced? I’m thinking of buying a new 400 sbc crankshaft and taking it to a machine shop. Would it have to be a specialty shop or can any machinist do this for me? I really like that idea and had never heard of that before. This would honestly make the rebuild a heck of a lot easier for me. Please correct me if I am wrong, but I should be able to use the 350 sbc 168 tooth flexplate and 350 sbc harmonic balancer: right?
I am new to the forum (any forum for that matter) but, really truly enjoy what I read and learn more every time I log on. Thank you for your help This is Great !!! Modern Technology |
#6
that is right. you could use all the 350 stuff (balancer and flywheel)
takes kind of a special shop to balance a 400 crank like that. However, I'm sure you can find a neutral balanced 400 crank at summit racing. |
#7
350's are balanced internally so the flexplate and harmonic balancer from a 350 will not work on a 400. A 400 is balanced externally and use a flexplate and harmonic balancer just for that purpose.
Hotrodding is much more than just owning a hotrod...It is a state of mind! |
#8
http://store.summitracing.com/partd...7I&autoview=sku
check out this crank. neutral balance, 3.75 stroke, for 300 dollars. |
#9
454,
Thanks Brother, I did not know that an internally balanced 400 sbc crankshaft existed. Wow! I found one on the internet and affordable too!!! Thank you ... really useful and helpful !!! .... This will save me a lot of time and money |
#10
my pleasure. make sure to get the crank that fits your engine block. there are lots of cranks out there. one piece and two pieces seals and cranks with different bearing sizes and chamfers and strokes. do your research!
good luck. |
#11
Check out Eagle rotating assemblys
http://www.eaglerod.com/products/Ch...assemblies.html they will balance it for you....and give you the correct flexplate and balancer. Quote:
#13
I used the above listed kit in my 383. it was balanced, stroker clearanced, and had the correct bearings for the .002-.003 clearances even though the mains were +.001.
I couldn't have been happier with it and it runs great. |
#14
Thank you all for the advice.
Back to top |
Similar Threads for: "400 sbc balancing problem"
| 400 - sbc | gilby246 | Engine | 4 | 10-19-2006 10:44 PM |
| 400 SBC Steam Hole Crack | ezobens | Engine | 5 | 03-20-2006 07:28 AM |
| 400 sbc overbore problem | al37ford | Engine | 8 | 07-21-2004 02:45 PM |
| SBC 400 and a saginaw 4spd ? | Brobob | Transmission - Rearend | 3 | 03-08-2003 04:52 AM |
| 400 SBC Balancing and info ? | Brobob | Engine | 8 | 10-31-2002 03:44 PM |
