Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 SBC Budget Build
Old 05-13-2012, 02:13 PM
Freddy62's Avatar
Freddy62 Freddy62 is offline
Originally Posted by 1971BB427
I would think that if the budget is tight you're headed off in the wrong direction already. The best bang per buck would be a 350 Chevy small block. Your 400 or even a 383 will not ever be a budget build, like a 350 is.
The 350 would be a huge step up from the 283, and would actually be less expensive to build HP with than a 283.
My "sediments" exactly. You can't beat the 350 Chevy for an economical build. In a light car such as this, a mild cam, dual plane alum. intake and a slight bump in compression (up to 9.0:1) will provide plenty of get up and go while at the same time, being very reliable.
