400 SBC Budget Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2012, 02:34 PM
I've got a 1962 Chevrolet II/ Nova that I bought a couple months ago for a first restoration job. The car came with a 283 sbc but it needs a lot of TLC and I really don't care for the lack of cubes. I'm thinking I will go with a 400 sb and see what I can do with it. The only problem is a lack of funding. Anyone have any suggestions?
Thanks!
Old 05-12-2012, 06:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
We don't have any idea what your question is, given that, F-Bird seems to have the right answer.
Semper Fi
Old 05-13-2012, 02:14 AM
Landshark928's Avatar
FrankenPorsche
What's your budget?
A 383sbc might be a cheaper way to go if you don't have a 400 donor block.
Old 05-13-2012, 12:48 PM
1971BB427's Avatar
I would think that if the budget is tight you're headed off in the wrong direction already. The best bang per buck would be a 350 Chevy small block. Your 400 or even a 383 will not ever be a budget build, like a 350 is.
The 350 would be a huge step up from the 283, and would actually be less expensive to build HP with than a 283.
Old 05-13-2012, 01:13 PM
Freddy62's Avatar
My "sediments" exactly. You can't beat the 350 Chevy for an economical build. In a light car such as this, a mild cam, dual plane alum. intake and a slight bump in compression (up to 9.0:1) will provide plenty of get up and go while at the same time, being very reliable.
Old 05-13-2012, 11:38 PM
BigEd36's Avatar
+1.......there is NO v8 engine you can rebuild more cheaply than a 350 SBC.
Old 05-14-2012, 06:06 PM
FrankenPorsche
How much more is a 383 than a 350 rebuild?
Unless you're just freshening up an old lump, it's close to even to add the cubes. If you're putting in a new crank anyway, 383 is the way to go for cheap streetable torue.
Old 05-15-2012, 02:43 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
cheap 400?
no such thing as a cheap 400 build. everything on a 400 is more expensive than a 350. if you line hone the main caps you need a special rear main seal. you can use 3.57 rods but have to buy proper pistons for the roads. in fact the 350 rods dwell longer and will give you a few extra ponies. i have a 400 block and crank for sale.
Budget 400 SBC build up elcamino74ss Engine 15 02-02-2011 07:22 PM
451m/400 budget build 72ltd400 Engine 2 07-18-2010 07:57 PM
Budget SBC build Roald Engine 49 05-07-2010 11:41 AM
SBC 400, help with budget build up! rsekrecre1 Engine 1 10-23-2007 10:51 AM
a budget 383 stroker build using a stock 400 GM Crank Mustangsaly Engine 7 10-15-2007 12:57 PM
