400 sbc build - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2010, 10:22 AM
400 sbc
Hi so i have a 509 2 bolt block im looking to spend around 400hp/475tq to the wheels any one have a good build in mind im trying to stay under $2000 thanks in advance.
KC
Old 02-12-2010, 10:23 AM
400 sbc build
KC
Old 02-12-2010, 10:25 AM
More info
the motor is going into a 86 elcamino. Im not sure about the trans yet thinking 700r4
KC
Old 02-12-2010, 11:24 AM
BG383's Avatar
BG
Check out this link here from a hotrodders forum:
list your 400 or 406 sbc combo's here,,, what works the best for you
These combos will give you an idea of what to exspect. As for 2k... I would say will come short of the HP/TQ goals that you want!!!
Old 02-12-2010, 02:12 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
you dont have a chance for 2k, you need to look closer to 5-7k, and then you mention a 700R4, which i am a fan of and that is what i run, but you will spend another 2k for a 700r4 and stall that will handle that kind of power
you mention 400rwhp and 475rwtq, to make this you'll have to be making around 500fwhp and 590fwtq (18-20% parrisitic loss) the ratio of hp/tq is kind of awkward for a SBC it would be very possible with a BBC, with any motor when you start making some serious horsepower your tq will not follow as much
example: i run a .040 383 with 525hp and 500tq
with the cams that it takes to make high hp you're not going to be able to make tons of tq as well.
if you want these kind of numbers you might as well be ready to spend about 8k+ for your drivetrain
Old 02-12-2010, 02:17 PM
Banned
buy $2000 in scratch offs and hope you win enough to build a boosted small block or a nice big block. Either way you're looking at atleast 5G's if all you have is a block.
Old 02-12-2010, 04:16 PM
DoubleVision's Avatar
Depending on what machine work needs done to the block as well as other pieces such as cylinder heads, cam, headers, intake, then your going to come up somewhat short. What pieces do you have?
Old 02-12-2010, 05:57 PM
Money/parts
Sorry i wasn't to clear when when i said i have a 509 block i meant a complete stock engine complete my brother has a 800 demon carb for me and i have a victor jr intake for it. the $2000 is just for the engine i have other money for the transmission/drive train. I am more curious as to the head/cam portion of the build and what could potentially get me to my mark which isn't set in stone
Old 02-12-2010, 07:41 PM
Parts
i have a victor JR intake and a 800 demon carb i haven't taken the motor apart yet but im sure there will be some minor machine work to be done maybe .030 over some clearance if i use 5.7 rods thats about it
Old 02-13-2010, 04:16 AM
What heads do you have? Stock smog heads will never reach your power goal. What cam? headers? If it`s a street machine I don`t recommend a Vic jr. I would use a dual plane intake. When I do a build, I keep in mind the combo needs to match to make max power. Along with matching components comes other items like stall converters, posi traction rears and gears.
Old 02-13-2010, 08:59 AM
i need to get new heads, pistons, cam ect im just not sure what would be the best combo for the car i would like to drive it around town every once and a while but its going to be mostly a 1/4mile car.
Old 02-13-2010, 10:12 AM
my87Z's Avatar
these are all really good heads that should get you there:
http://www.competitionproducts.com/D...o/10320010PK2/
http://www.competitionproducts.com/D...o/10520020PK2/
http://www.competitionproducts.com/B...fo/BRO1021001/
http://www.competitionproducts.com/R...fo/RHS12319K2/
i dont know exactly the use of the vehicle but these cams with the heads listed above should have you over 500hp with the right tune
http://www.competitionproducts.com/H...nfo/112061-06/
http://www.competitionproducts.com/H...ctinfo/110102/
http://www.competitionproducts.com/H...ctinfo/112071/
http://www.competitionproducts.com/H...ctinfo/111011/
these are just ideas, they will make some great power, but you need to research what you really want and make an educated pruchase. you will likely still have a hard time keeping the price below 2k, your previous post was a little confusing so i still dont know if you will need to build a short block or not, but if so the short block will take up the majority of that 2k, and if you have a complete stock 400, you will need to rebuild it with a new rotating assembly in order to handle the 500hp
Old 02-13-2010, 12:45 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
FYI This is a double posting.
Plus a stock 509 small block ?
Luv the smell of NITRO in the morning.
Old 02-13-2010, 12:46 PM
1BAD80's Avatar
Wiki Edits: 2
Old 02-13-2010, 12:52 PM
engineczar's Avatar
These two posts have been merged, post away!
BSE Racing Engines
Sbc 400 Build Up BIG E 86 Engine 6 01-01-2010 06:15 PM
400 sbc build stovepipe699 Engine 5 12-29-2009 10:09 PM
sbc 400 build 53streetrod Engine 7 05-23-2009 09:02 AM
fresh sbc 350 build 400 hp poss? jasont/a83 Engine 28 05-03-2009 09:21 PM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 03:44 PM
