400 SBC Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 02:33 PM
400 SBC Build
Hello guys and if any gals,
I am seeking out help on a project I am in the middle of. I purchased a 1993 truck that had been so badly overheated it cracked both heads. So for the cost of rebuild I found a steal of a 400 sbc freshly rebuilt with 0 miles and 350 heads(non vortech). After looking at prices it is cheaper for me to run vortech heads on this 400 and keep the existing fuel injection and headers. the 400 is bored .30 over and Im not sure what size cam it is(im replacing anyway). I want something pretty mild. The heads are 350 vortech angled plug.
Any suggestions, concerns, comments, help??
Old 02-02-2012, 02:52 PM
DoubleVision's Avatar
What injection system are you referring to? If you mean the stock TBI system don't waste your time as it would require alot of work in the computer as a 400 is 50 cubic inches larger. If your referring to a factory vortec injection system the computer will have to be reflashed and alot of other mods.
Old 02-02-2012, 03:14 PM
Thanks. I was wondering if it would be able to keep up. Guess Ill be saving the $ on the vortech heads and going to a carb. 650 or 750?? What would be a good set up for this engine? I am not looking to go to big on the hp.
Old 02-02-2012, 03:59 PM
Banned
If you use a mild near stock cam the factory efi can work if you bump up fuel pressure by about 20% its not perfect but it will work.
355 build??'s about compression and build impalaman355 Engine 5 06-06-2011 11:20 AM
360 Build Eric63M Engine 0 08-29-2010 06:07 PM
305 build help RaticalRods Engine 25 08-24-2010 08:32 PM
USA BUILD vs CANADIAN BUILD? troy norrad Hotrodding Basics 19 02-18-2008 10:57 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 08:36 PM
