400 sbc build tell me what you think
the engine is a early 70s 400 sbc 509 casting .30 over
with rhs 64cc vortec heads with 170cc runners cam lifters rods pistons from a summit kit saying this engine should build 350-375 horsepower (with everything else stock) cam has hydraulic lifters with roller rockers on top the heads offenhauser intake i believe is a single plane 10.5-1 compression ratio and looking to run nitrous does all this seem to be able to hold a 150 shot for weekly drag and occasional driving also cfm carb should i use for this setup thinking with the nos a 750 or 800? 85 buick regal considerably stripped out is going to be the recipient |
the rods are aftermarket from summit but they are stock specs the pistons are hypertech domes
For every 100hp start with 2 heat range colder plugs not hotter or you'll have detonation problems plus you'll need to go 2 degrees less timing and learn about reading the plugs, the nitrous directions should tell you this. It's wise to be conservative on your tune 1st time out.
domes? Reverse domes right? otherwise your compression is WAY too high. What are the cam specs? at 10.5:1 you're going to need a healthy sized cam. Heads are too small for that compression and displacement.
i found a set of afterburner headers that will fit in the cutlass any horror stories withese out their
oh and i also have the smaller 6 3/4 inch harmonic balancer should help twist it up a bit better
Good luck.
To go with the 6 3/4" balancer you will have to go with an internally balancerd flywheel/flexplate and crankshaft
Shane |
? Internaly balanced crank,Its at the machine shop now having the rotating assembly balanced .Shane |
http://www.damperdoctor.com/Merchant...egory_Code=CHE and here's the same thing for use with a 12:00 O'Clock timing tab...... http://www.damperdoctor.com/Merchant...egory_Code=CHE Use a toothpick to apply yellow paint into the TDC groove on the outer damper ring so you can see it easily with a timing light. |
Thanks
Shane |
| sbc 400 build | 53streetrod | Engine | 7 | 05-23-2009 09:02 AM |
| fresh sbc 350 build 400 hp poss? | jasont/a83 | Engine | 29 | 05-03-2009 09:21 PM |
| 400 cid SBC | Shades_o_Grey | Engine | 20 | 02-04-2008 12:28 PM |
| 400 - sbc | gilby246 | Engine | 4 | 10-19-2006 10:44 PM |
| 400 SBC Newbie | thecamaroguy | Engine | 13 | 12-08-2004 08:09 AM |
