Thread Tools Search this Thread share on Facebook
  #16
Old 01-01-2012, 05:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
Originally Posted by manchildau65
I lined the dot to the zero timing mark (also where key way for crank was).
The "straight up" pip or dot of the crank gear is not aligned w/the woodruff keyway! If you aligned the cam gear to the crank gear's keyway, the cam phasing is radically off.
Register now (free) or login to remove ads
Old 01-01-2012, 05:08 PM
manchildau65 manchildau65 is offline
Now you're scaring me... I definitely lined the dot up with key way.. But key way said zero on it??? I think I took pic, let me try to post...
Old 01-01-2012, 05:27 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
That's exactly why i ask if you did the timing chain swap, i was wondering which location you set it at, and i agree with Mark it's going to be way off.
Cole
Old 01-01-2012, 05:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
There are two "zero" pips- one is to designate which of the three keyways is used to set the cam where you want it- retarded, advanced or (in your case) straight up. THAT pip is located next to the keyway itself. The other round pip is the one used to align the cam and crank gears, and is out by the teeth, and it's not aligned w/the keyway- at least on the three way timing sets I have used.
Old 01-01-2012, 05:34 PM
Yet another reason why I need to get a decreeing wheel!!!
Guess, I'll tear it down again... Going to still do compression test first... For sanity reasons! It'll also give me an excuse to finalize my serpentine swap. Let me get pic up first.. Last cam I ran a tooth off and have pic during tear down to show set up.
Old 01-01-2012, 06:33 PM
tjet tjet is offline
Good catch cobalt
Old 01-01-2012, 06:41 PM
I just checked picture, i'm off by two teeth, @$&*****&$!!!!
Old 01-01-2012, 07:09 PM
larrywalk larrywalk is offline
With the SBC, the keyway aligns with the #1 crankshaft journal. Therefore, when the keyway is 45 degrees to the right of straight up, the #1 piston will be at TDC.
TDC puts the dot on the crank gear straight up; just align the dot on the cam gear straight down next to it. Note that this puts the camshaft index pin at 3 o'clock - this is the firing position for #6 which is also at TDC. When you turn the crank a full turn, the cam dot will now be straight up, and #1 will be in firing position.
Old 01-01-2012, 07:14 PM
So having the timing gear off by roughly 45 degrees does this make sense that I have low power, diesel sound, but still able to fire and run at idle?
Old 01-01-2012, 09:22 PM
ssmonty ssmonty is offline
please delete
Old 01-02-2012, 12:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
I would suggest you go ahead and check for bent p-rods and look closely at the possibility that the valves and pistons could have gotten together.
Because the cam is relatively mild, this may not have happened. But there's no saying for sure w/o checking. A leak down test would tell you what you need to know, a compression test will do if that's what you have to work with- just check the p-rods and realign the cam gears first before testing.
Old 01-02-2012, 06:56 AM
454C10 454C10 is offline
your photo looks right to me.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "400 sbc cam swap problems"
ThreadThread StarterForumRepliesLast Post
5.3l to 6.0l GM swap problemsChapo 1Engine201-26-2009 05:35 PM
350 Swap problemstjsyjEngine308-20-2007 08:00 PM
problems after cam swap1973monteEngine2410-18-2006 12:06 AM
tranny swap problems.rat macTransmission - Rearend108-05-2005 09:06 AM
Rear end swap problemsdatsun daleTransmission - Rearend112-17-2002 10:50 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
