400 sbc combo advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 05:16 PM
SPEED MASTERS CC's Avatar
I purchased a long block from a friend, a .04 over 400 sbc with pocket ported 200cc sportsman 2 heads, with hydraulic flat tappet cam that is 244/250 at .05 and .540 lift, 106 lca, 5.7 rods and hyperutectic flat top pistons. This motor is going in my 2400lb 32 ford strip/street car. I need a converter recommendation (Turbo 400 with 4.56 gears/30 in dia. slicks). I am considering changing the hydraulic cam for a solid. (I am concerned about the hydraulic cams 106 lca being to tight for street use?) Would I pick up much power going to a mech. cam? What would be a good choice for intake and carb.
Old 08-21-2011, 05:34 PM
I would leave that cam in there. That is a healthy cam. A 106 will make it very choppy at idle, and not a lot of vacuum for brakes (if you have power brakes), but it will scream on the top end. I'd suggest a minimum stall of 4000rpm. With such a light car that you have it will still drive fine. The converter won't flash much when you are just cruising. You'd only pick up power with a solid if you go north of 250 degrees, and you might run into clearance issues.
For an intake I would run a good single plane such as an Edelbrock Victor jr, or a competing brand. For a carb i'd run something like a QFT 850 right here:
http://www.summitracing.com/parts/QFT-Q-850/
I had the opportunity last week to tune a QFT carb, and I am very impressed by the adjustability and the quality of the carb.
Advice needed on head/cam combo please classickrazy Hotrodding Basics 9 06-23-2011 10:39 PM
Seeking combo advice... roach4047 Engine 4 08-06-2010 06:07 PM
advice for 396ci combo roy383ci Engine 33 11-17-2006 07:03 AM
advice for 454/TH350 combo darom Transmission - Rearend 12 02-18-2006 06:43 PM
could use a little advice on this Engine combo I am putting together 427 cui ProStreeter 67 Engine 2 09-07-2003 06:22 PM
