400 sbc crank in a 350 block - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2009, 12:33 AM
Last journal entry: Well, about that mustang...
i have a 350 sbc motor broken down to the short block and im considering swapping crankshafts... i know i can purchase a 400 crank to make it a stroker motor or so ive been told.... what all do i have to change if i swap crankshafts... sorry if this is a rookie question but hey...im a rookie! thanks in advance
Gearhead
"Drive It Like Ya Stole It"
Old 10-27-2009, 12:54 AM
techinspector1's Avatar
Wiki Edits: 326
Cheapest/best way out in my opinion is Scat 9000 series cast STEEL crank. You can buy the unlightened, external balance crank for 189 bucks. Get a 400 balancer/damper for 90 bucks and a 400 flexplate for 40/50 bucks off ebay and you're good.
Here's the crank....
http://www.summitracing.com/parts/SCA-910375/
Rebuilt balancer/damper from Damper Doctor...
http://www.damperdoctor.com/Merchant...egory_Code=CHE
This assumes you have a 2-piece seal block and don't want to spend the extra dough to internally balance the rotating assembly.
You have your choice of using stock length 5.7" 350 rods or aftermarket 6" rods, depending on the piston you use. I like the shorter rod because the 6" rod puts the wrist pin up into the oil ring. Maybe no big deal, I just don't like it. I like these rods for a street or mild street/strip motor...they're clearanced to prevent cam lobe interference with a standard base circle diameter cam...
http://www.summitracing.com/parts/SCA-25700P/
Old 10-27-2009, 06:25 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
You can't just put a "stock" 400 crank in a 350 block. You need to have the main journals ground down because the 350 uses 2.449" and 400 uses 2.649" main journal sizes. But like tech suggested you can get aftermarket cranks that are designed to fit into 350 blocks with no machining.
Secondly you have to consider your stack height.
If you put a 3.75" stroke crank in a 350 with 5.7" rods and a stock 1.560" compression height piston from a 350, the piston will be .11" inches above the deck.(Assuming you have a stock deck height of 9.025")
Another option If this were a strict budget build would be to use the stock 5.565" rods from the 400 and then you can use the stock 350 pistons and your stack will come in at 9"
IMO If you are replacing the pistons go with 5.7" rods and find a piston with the correct compression height. If you go to summit they have complete rotating kits for the CID you are after. You can get them balanced internally or externally. Hope this helps
Old 10-27-2009, 09:00 AM
scat 9000 crank
I have talk to people who have claimed that the scat 9000 crank sometimes needs 3 pieces mallory to balance making it more expensive than the forged unit.Anybody else had this problem?
Old 10-27-2009, 09:33 AM
Wiki Edits: 326
You may have to do that with anybody's crank, depending on the weight of the piston, rings, wrist pin and rod. If you use heavier than stock components, you must expect to equalize those weights at the crank counterweights. I don't think it's fair to make a blanket statement about anybody's crank. Not taking up an argument for Scat, just stating what's real.
Old 10-27-2009, 09:51 AM
So if i go with a scat crank and stock components with flat top pistons (4 valve reliefs), and stock rods should I need something else to help balance the motor or just the harmonic balancer recommended?
Old 10-27-2009, 10:13 AM
Crank
I understand your answer,but that doesn't answer my question.I am not attacking scat . I have used there parts many times and have had good luck with them,but i haven't used their cast stuff.We have a crank grinder who will not do their crank balancing because of this,I just wondered if anybody else has had this problem and what parts were used.
Old 10-27-2009, 10:50 AM
http://www.speedwaymotors.com/Econom...mbly,3176.html
Old 10-27-2009, 03:33 PM
Well to let you know I have bought two scat 3.480 crankshafts that where both cast steel and the same rods as stated above by techinspector and one set was with forged pistons and the other was hypereutectic pistons and the machine shop did not have to hardly do anything to the crank just a little drilling and that was about all. Yes my crank was the 3.48 internal balance but compared too the 3.750 external balance unit it should not make that much of a difference to a degree. My one cranks was for a one piece rear main seal block and the other a two piece rear main seal. Machine shop said my rods and crank where spot on for the specs. Hope that might ease your worring.
Eric
Old 10-29-2009, 08:13 PM
Eagle internal balance crank in my 406,eagle rods 5.7" and kb pistons. minor grinding on roads and very minor drilling on crank.
Shane
Old 11-04-2009, 06:53 PM
Hey NTX Gearhead.......
Whynot....with all the stuff out of the engine....get the Scat crank and ALL the related movung parts balanced at a machineshop? Problem solved for around $75.00/100.00. When swapping in new...used...aftermarket...modified..etc. etc.parts into one moving assembly....really ruins your day when you fire it up and it shakes itself to death. When you coulda spent alittle more and not hafta re-do your work. My oppinion.
6sally6
Old 10-04-2010, 07:31 AM
Balance question
Any real critical difference between internal vs external balance on the crank for building a sreet/strip enngine? Worth the extra $$ or not?
Need help on leaking crank seal sbc 350 eric32 Engine 2 09-22-2009 03:49 PM
What to consider when choosing your first SBC build? CandiMan Engine 16 05-25-2009 07:50 PM
what does a 400 sbc short block weigh? 406 ss monte Engine 2 10-18-2008 04:23 PM
SBC Strokers - 350 vs 400 Blocks & Combos (not just 383 & 406) ez2cdave Engine 11 05-21-2007 09:34 PM
350 Block - Heads - Crank Combo nightrain_rod Engine 0 07-06-2003 10:50 PM
