400 SBC, do i need bigger camshaft ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2013, 07:26 PM
Engine is 1975 model, the block # is 817 and it's 2 bolt block with main studs Heads are # 882 that have been pocket ported and do have 1.94"/1.5" valves. It's been bored 0.030" over and has piston's that gives 8.75:1 compression Crankshaft and rods are stock.
This engine is going into a 1971 Vega # 2700 lbs curb weight, Th-350 trans, 3000 stall TCI streetfighter converter. 12 bolt with 4.10 gears and posi. and the tires are 275/60x15. Current cam is Crane 260 - H-260-2 Hydraulic Flat Tappet Camshaft for Chevrolet 1957-1987 V-8, 262-400 intake is 2101 Edelbrock Performer, 750 cfm Holley 4150 sitting on top of a 1" spacer. headers are 1.3/4" long tube's with dual 3" exhaust.
This is mostly a street car, but i would like to race some 1/4 mile drag racing once in a while. 75% street / 25% strip
Old 05-26-2013, 08:25 PM
vinniekq2's Avatar
not a great cam but I guess ok
Old 05-26-2013, 08:45 PM
techinspector1's Avatar
Wiki Edits: 326
That cam is perfect for the static compression ratio of the motor. If you want to run more cam, raise the static compression ratio. Be aware though, there is only so much to be had with those heads. More cam would need more heads also. The camshaft is not a single item that stands alone in the motor, it has to be custom tailored with the other characteristics of the motor. Although not all members of this board like this chart, it will give you some idea of the static compression ratio that you will need with what cam timing.
http://www.crankshaftcoalition.com/w..._compatibility
Also, be aware that present day drag racing is actually bracket racing, so that anyone can run alongside anyone else. Theortically, a VW Beetle could race a Fuel Funny side by side, if the Funny didn't do a meltdown waiting for the light. Both cars will have a dial-in on the window and cannot go quicker than their dial or they lose. It's not like it used to be, where the fastest car went home with all the winnings. Now, you have to dial in respectably and cut a good light on the tree.
Old 05-27-2013, 01:25 AM
Those cams are bigger than i had in mind. How high is a safe redline on a 400 SBC ?
I was thinking about a camshaft that has redline of about 5500-5800. But i guess you guys are more experienced than me when it comes to hot rodding.
Old 05-27-2013, 06:02 AM
Yes they are dished pistons, but smaller than stock.
Is it ok to rev a short rod 400 sbc to 6000-6500 rpm without a catastropic failiure ?
Old 05-27-2013, 06:32 AM
vinniekq2's Avatar
Is your engine balanced and well put together?
Old 05-27-2013, 12:25 PM
The engine has not been balanced, Stock crank and rods and 0.030" over pistons. All clearance is good and the mains do have studs.
Old 05-27-2013, 12:30 PM
Banned
With that light car and gears and stall it'll be quick without much power. If I was to put a cam in that engine I'd like the 274h06 with 1.6 rockers. It's very easy on valve train and works great in low compression engines. It's cheap too. You won't see huge gains over what you have though, maybe 20hp as those heads are really choking it down.
Old 05-28-2013, 12:48 PM
How much power should the engine be in the form it's now ? Hp and torque ?
Should peak torque be over 3000 rpm ?
Old 05-29-2013, 08:00 PM
300 hp +/- ?
Old 05-29-2013, 10:24 PM
You have a PM
Old 06-02-2013, 07:32 PM
no one ?....
Camshaft moves too much - SBC 400 Dino308gt4 Engine 13 03-12-2008 01:41 PM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
Help me design a 400 SBC around this camshaft shockers69 Engine 9 02-12-2005 08:27 AM
Bigger exh manifolds for SBC? FASTCHEVY Engine 18 05-08-2004 10:34 PM
bigger cam for sbc 66truck4spd Engine 11 04-28-2004 01:10 PM
