400 (SBC)flywheel/ bell-housing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2011, 12:34 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Hey guy's, i have a guy that want's to trade me a M-21 transmission for a set of factory Boss 302 valve covers i have had for several years, And what i need to know is weather this M-21 can handle 500 plus HP in my camaro, And also what would be the best flywheel for this app and what would be a good bell-housing to get also. All advice is welcome not really sure exactly what i want to get for this if i go with this trans. Oh and he has a M-20 also he mentioned trading if i didn't want the M-21. The M-20 is supposed to be like a 65 model and the M-21 is a 69 model by the #s supposed to be from a 69 camaro. Just needing some advice from you guy's on this.
Cole
Old 05-14-2011, 01:48 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Cole
The M20, M21, & M22 are about equal with the M22 having straighter cut gears. The 20 & 21 are newer then the 22 & they have smaller syncro rings, but you can use the 22 rings but you must use the corresponding/correct 22 syncro hub with them. It's more then adequate for the power your putting out.
Rich
PS I think I'd use a Lakewood Bell housing.
Fly wheel? Billet SFI approved.
Old 05-14-2011, 02:56 PM
eloc431962's Avatar
Wiki Edits: 37
Thank's Rich, you are talking about the billit steel correct ?
Cole
Old 05-14-2011, 03:42 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Cole, if this is going to be used on the street, I would suggest that you use the wide ratio M-20 as opposed to the close ratio M-21 unless you have real deep gears. The 2.20 low of the M-21 is hard on the clutch when trying to start out easy.
Old 05-14-2011, 03:50 PM
Cole
Yes the billet steel wheel, I'd only use Aluminum on a track only car.
Rich
Old 05-14-2011, 05:17 PM
3rdmember
take it for what it's worth, get a quicktime bell...
lighter and more compact.
a little more $$$ though but worth it.
will the muncie handle 500 horses?
if the car hooks, maybe....
btw, they bring about 500 bucks on up around here...
Old 05-14-2011, 07:41 PM
willowbilly3's Avatar
Last journal entry: Body mods
I have seen at least 2 M-20,21s scatter their guts on the ground behind pretty stock 327s. I doubt one could take any abuse behind 500 hp.
Old 05-14-2011, 08:00 PM
eloc431962's Avatar
Wiki Edits: 37
Thank's to all of you for your input i really do appreciate it I have i think talked myself out of this trans swap, Ex-specially since i have already shredded a BW-Super T-10 with this engine I am now thinking about going with a TKO-600 or something along that line , i don't know alot about them but do know a few guy's that are running them and really like them so far. Oh and Bill i am running 3.73s with 26inch tall tires right now with a TH-350 and a 3000 converter. It will be mainly street driven after this swap might see the track from time to time well i know it will i can't help myself i love the track. It's been a while since i have had a stick back in this car and i really love to shift the gears and it being a factory 4-speed car i would just like to have it back in it.
Cole
Old 05-14-2011, 09:48 PM
Cole
That TKO would be a far better choice. A bit pricy, but that's what it takes to run with the big boys...
Rich
PS The other upside, you get to keep the valve covers.
79 Nova Bell housing and flywheel kimrobertson Transmission - Rearend 26 04-18-2011 06:37 AM
Which Bell Housing and Flywheel? kimrobertson Hotrodding Basics 26 04-06-2011 08:10 PM
Dodge poly bell housing; what manual transmissions fit the bell housing? Hemi-Meadowbrook Transmission - Rearend 2 03-08-2011 09:07 PM
GM Bell Housing super_silent Transmission - Rearend 2 11-07-2007 09:01 AM
Bell housing JAFO Engine 1 10-05-2002 04:27 AM
