400 sbc head - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2006, 07:04 PM
400 sbc head
I'm building a 400 sbc for the street. When I purchased the block my intentions were to build a racing engine, now just a street engine. I bought a set of Brodix track 1 heads from a guy, these heads have huge valves and ports and I really don't want to use them on the street.
My question is how do you determine the best head for your application? Is there a stock head that is better than others? Is there a stock head with a little work could be a good head?
Any help will be greatly appreciated!
Old 07-31-2006, 07:44 PM
crossfire84's Avatar
Tri-Powers are cool
I would rethink this, I have a 406 sbc with these heads, the response is unbelievable, this thing pulls like a big block, makes 420 dyno hp, gets 20 mpg in my 84 vette with modified twin tbi.
Old 07-31-2006, 07:47 PM
400sbc
What intake did you use? I have a matching very high rise, I thought with the large ports and valves I would get less torque....
Old 08-01-2006, 09:29 AM
That head is just fine for a 400.
Old 08-01-2006, 10:21 AM
shaggy56's Avatar
I know someone running the Track 1s fully ported in a 406 on the street and hes putting down like 500 hp and runs in the 11s. He gets real good gas mileage because its fuel injected and runs smooth with a street intake and mild cam. He wants to run single plane and a more aggressive cam to see what the heads really can do.
Old 08-01-2006, 04:34 PM
400 sbc
Thank you for your help! I think I will go ahead and run these heads. Got any suggestions on cams for this engine? I guess I will run the hi - rise intake that is matched to the heads as well.
Old 08-01-2006, 05:47 PM
Tri-Powers are cool
I'm using the stock looking twin throttle body intake, to use on track 1s you need to do a lot of port work, but it was worth it, the cam is an edelbrock performer RPM item, [1500-6500 rpm] hyd.very mild idle, you mite look into this. works great with power brakes. hope this helps have fun.
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 07:29 PM
max 400 sbc 6speedwagon Engine 18 02-02-2011 12:27 PM
Broken 400 SBC flexplate with a 350 block... realsquash Engine 5 04-20-2004 11:23 AM
Building BIG HP 400 SBC Sampson Hotrodding Basics 11 04-04-2004 12:52 AM
SBC 400 heads wcpalmex Engine 2 06-15-2003 08:56 PM
