400 sbc & heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2008, 08:52 PM
400 sbc & heads
hi guys...i have 400 sbc #3951511 and a set of heads #333882...i ran the numbers and came up with 1975-76 and 1970-80 on the block and heads...The heads also had some numbers for the 350...if i remember right 75-76- years were the 4 bolt mains which mine is...the heads i ran on a 350 blower motor in the early 80's...as you probably figured out, i don't know to much about the 400...and please bare with me...i'm 57 years old been a gear head all my life as well as raced rear engine Dragsters in the 80's...my problem is i had 2 strokes a little over a year now and i finally started getting some memory back...i noticed these heads will accept an 7/16 push rod and they have Manley guide plates...i really don't remember them...my wife said they were on the street blower car...their 2.020...looks like no porting work...they also have about 1 inch pipes coming out the front which i think thats how i cooled the heads...back then no inter coolers...i cant remember if i had the block cemented or not...i just got up to speed about the steam holes in the heads and plugging and drilling some holes in the block using a felpro gasket...my question is will theese heads work since they were listed in my book they came stock in 75-76...thanks guys for the time...rock
Old 08-26-2008, 09:40 PM
SSedan64's Avatar
They should work fine as long as they have the steam holes for street use. They aren't great performance heads but will work.
http://www.gregsengine.com/350to400.htm
http://www.chevytech.com/2c42o2.html
http://www.chevytech.com/2c42o1.html
Cooling Mod you referred to>
http://www.chevytech.com/3c10o20.html
SBC Heads -= AFR - Trickflow - Dart - Brodix =- Delirious2000 Engine 25 04-22-2009 12:58 PM
Recommend me a build! 400 sbc, 64cc heads bunni Engine 4 03-17-2007 08:14 AM
400 SBC Newbie thecamaroguy Engine 13 12-08-2004 08:09 AM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 03:44 PM
SBC Heads fred56 Engine 4 10-27-2002 07:54 AM
