Thread Tools Search this Thread share on Facebook
  #1
Old 02-23-2009, 10:48 AM
Blackdevil400 Blackdevil400 is offline
400 sbc heads
What is the best set of heads for a 400 sbc? casting number 3951511
i want a mild build with decent torque and horsepower.
Register now (free) or login to remove ads
Old 02-23-2009, 11:01 AM
327 / 350 hp's Avatar
327 / 350 hp 327 / 350 hp is offline
400 sbc heads ???
you sure the # is right ,, cannot find that #. Most 400 engines were lo comp and detuned for emissions.
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Vortec heads work very very well for this.
Old 02-23-2009, 12:18 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
Bone stock L31 Vortecs. Casting number 12558062, rescue from the boneyard, disassemble and magnaflux for cracks. 5-angle valve job, new seals, drill for steam holes.
http://www.gregsengine.com/350to400.htm
Bore block 0.030", deck for 9.008" block deck height. Install Keith Black 30cc KB126 pistons on 5.7" rods. Fel-Pro 1014 head gasket. Zero piston deck height with these components and block at 9.008" with 0.039" squish and 9.1:1 static compression ratio. Edelbrock RPM intake with 650 carb. 1 3/4" equal-length, long-tube headers. CompCams 12-234-2, XE256H cam, 256/268, 212/218, 0.447"/0.454", ground on 110 LSA, installed 2 degrees advanced.
This is a daily driver grunt motor that can be operated with a stock torque converter on 87 octane swill. The power is all done by 5000, so will work well with a stock rear gear. Check out the torque at 1500.
RPM HP TQ
1500 120 419
2000 171 449
2500 213 446
3000 263 460
3500 310 464
4000 341 448
4500 353 412
5000 318 334
Old 02-23-2009, 12:57 PM
ap72 ap72 is offline
How fast is fast enough?
RPM HP TQ
1500 120 419
2000 171 449
2500 213 446
3000 263 460
3500 310 464
4000 341 448
4500 353 412
5000 318 334
Mate that to a 2500 stall conv. and 3.73 gears and invest in some stock of your favorite tire company- I predict their sales will be going up.
I would have narrowed the LSA a bit, but it is a GREAT example of very streetfriendly power. It'd idle like a caddilac too.
Old 02-23-2009, 01:33 PM
F-BIRD'88's Avatar
Yada Yada Yada
Now you're cookin' with gas!!
Old 02-23-2009, 05:03 PM
RustoRod RustoRod is offline
I have a Vortec headed 400 with a 268 High energy comp cam that specs 218/218 @ .050. It runs about like Tech inspectors simulation. It is good on fuel and passes emissions. Having said that think about what you might do with the vehicle and parts that you have now. A set of Dart Iron Eagle platinums in the 200 cc size will still make great low end torque and make more power at high rpm. It is just something to think about.
Old 02-23-2009, 10:26 PM
Chevrolet4x4s Chevrolet4x4s is offline
How good is good?
Shane
Old 02-27-2009, 01:51 PM
thanks everybody the 350 to 400 really helps
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "400 sbc heads"
ThreadThread StarterForumRepliesLast Post
Recommend me a build! 400 sbc, 64cc headsbunniEngine503-17-2007 08:14 AM
400 SBC NewbiethecamaroguyEngine1312-08-2004 08:09 AM
sbc headsJaredEngine703-03-2003 07:07 PM
400 SBC Balancing and info ?BrobobEngine810-31-2002 03:44 PM
SBC Headsfred56Engine410-27-2002 07:54 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
