400 sbc horsepower stumped - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 10-14-2012, 09:48 AM
vinniekq2's Avatar
10 mph is good for low 12s or better
  #77 (permalink)
Old 10-14-2012, 10:36 AM
F-BIRD'88's Avatar
Yada Yada Yada
Hold off on the spray idea until you have the N/A motor tuneup all sorted out.
The fuel curve must be dead on or you will hurt parts.
The mechanical pump (alone) is a mistake$$$ with nitrous.
Again been right where you are at. Been playing with small and big nitrous and going way to fast, for some 30 years on cars like yours and mine . And some silly powerfull racey stuff too.
The Hyd roller cam (limited rpm capability) is a point too with nitrous.
You do not want engine fuel in consistant -leanout or valve float-hyd lifter pump up with N2O. $$$$
Bad things happen fast on nitrous.$$$
You are not there yet.
  #78 (permalink)
Old 10-15-2012, 12:10 PM
ericnova72's Avatar
More for Less Racer
I totally agree with this...you need to really finish sorting out all the little things naturally aspirated first.
Don't even think about nitrous without an electric fuel pump.
"Bad things happen fast on nitrous" is an understatement for those who don't have all their ducks in a row first. It will happen faster than you can even begin to react to save the engine...literally "the blink of an eye".... and the engine is hurt.
Along with the fuel curve, the ignition timing has to be corrected for the nitrous use.
400, engine
If you do not want to register, fill this field only and the name will be used as user name for your post.
how can I max horsepower in a 400 sbc devarsity61 Hotrodding Basics 18 09-17-2012 01:37 AM
wanting a horsepower/torque estiment turbo sbc 400 andrews72400 Modern Electronic Engines 1 06-01-2012 06:05 PM
max horsepower in a sbc 400 devarsity61 Hotrodding Basics 27 06-01-2011 08:04 AM
400 horsepower?? 303oldskool Engine 36 02-13-2009 11:34 AM
how much horsepower for a 400 sbc hause Engine 2 03-13-2006 09:27 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
