Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 sbc hp?
Thread: 400 sbc hp?
Old 02-21-2013, 10:58 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
vortec heads are limited to mid 400s plus or minus.If you use a hydraulic flat tappet look closer to 400. You can use a 750 cfm carb of bigger,depending on application.You will have good low RPM torque with those heads
