400 sbc hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2013, 11:28 PM
400 sbc hp
i have a 400 sbc 2 bolt main bored .40 over a 400 crankshaft and dishtop piston and the heads are #3970126 and edelbrock 650 four barrel carb and a edelbrock performer rpm air gap intake and a comp cam hyd flat tappet 275deh 275/277 219/229 @50 462/482 110 lobe can anybody tell me about the hp and torque
Old 05-27-2013, 11:59 PM
vinniekq2's Avatar
350/430 ish,not enough information.you need a bigger carb
Old 05-28-2013, 03:57 PM
techinspector1's Avatar
Wiki Edits: 326
So, you have no idea what the static compression ratio is, but you chose a camshaft anyway. Perfect.
Old 05-28-2013, 05:59 PM
400 sbc hp
the motor was already in the car when i got the car i will try to get some more information about it and thanks alot
Old 05-28-2013, 08:20 PM
400 sbc hp
sorry guys it's not a air gap intake it's just the performer rpm intake the guy said it has 9.5 to 1 compression hyperutectic piston 5.7 stroke rods shorty camaro headers i hope this helps and thanks agian
Old 05-28-2013, 09:55 PM
Wiki Edits: 326
RPM....HP....TQ
2000...155...406
2500...195...410
3000...245...428
3500...281...422
4000...305...400
4500...307...358
5000...273...287
Peak volumetric efficiency 82.6% @3500
Peak BMEP 161.1 lbs @3000
The Following User Says Thank You to techinspector1 For This Useful Post:
plumcrazyopa (05-28-2013)
Old 05-28-2013, 10:52 PM
400 sbc hp
thank you sir
Old 06-04-2013, 12:47 PM
400 sbc hp
if i can change heads with 3991492 or 3947041 or keep the heads i have now whats the better head out of the three
400 sbc. . T-400 or 700r4 blackpanther68 Transmission - Rearend 2 08-05-2012 06:32 AM
400 sbc 69 C-10 stepside Engine 9 10-27-2010 06:51 PM
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 07:17 PM
400 sbc monte mike Engine 7 10-03-2006 10:56 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 10:02 PM
