400 sbc hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2013, 10:59 PM
400 sbc hp
can anybody tell me what degree to set my cam on for the best alround performance
Old 06-02-2013, 12:24 AM
techinspector1's Avatar
Wiki Edits: 326
Yeah, I'd install it straight up on the marks given on the cam card. Advancing the camshaft in relation to the crankshaft will take away some power at the top of the range and replace it at the bottom of the range. Retarding the camshaft in relation to the crankshaft will take away some power at the bottom end and replace it at the top end of the range.
If a fellow was putting too much torque to the tires off the line, he might consider retarding the cam. If he needed more torque off the line to improve his 60 ft. number, he might advance the cam a little. If you have to move the cam more than 4 degrees advance or retard to get the results you want, then you have chosen the wrong cam in the first place.
The Following 2 Users Say Thank You to techinspector1 For This Useful Post:
plumcrazyopa (06-02-2013), vinniekq2 (06-02-2013)
Old 06-02-2013, 06:02 PM
400 sbc hp
Thank you sir that helps alot
400 sbc. . T-400 or 700r4 blackpanther68 Transmission - Rearend 2 08-05-2012 05:32 AM
sbc 400 okc87ssmonte Hotrodding Basics 2 09-26-2011 01:53 PM
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 06:17 PM
400 - sbc gilby246 Engine 4 10-19-2006 10:44 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 09:02 PM
