400 sbc mains - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-05-2008, 03:34 AM
racecar100's Avatar
Ok! We had a 350 came back like the just after we build it one time done the same thing. What I found is that someone who finish assemble putting the accessories on the engine is they did not clean and inpect the oil filter adaptor which it have the built in oil cooler (like the one put on chevy pickups). The bypass valve was cracked and not seating along with lots of sandy grits inside the adaptor. The grits is not metal it was more like fine sand.
So we did regrind the crank and reclean the whole engine. Told them to go get a new oil filter adaptor them never had any problem. I don't that the same problem you may have, but iI would check the bypass valve on the oil filter adaptor to just in case it might be the key to your problem.
  #17 (permalink)
Old 03-05-2008, 03:55 PM
400 mains
Yes I did check the oil filter bypass valve, it looks fine but I plan to change it anyway, Sam-Missle the thrust faces are the only part of the bearing that dose look good.
  #18 (permalink)
Old 03-05-2008, 06:43 PM
as machine tom asked, you should look at the main line sizing, crankshaft size and straightness, and balance.
sam-missle
400 SBC: Where is my torque?? ezobens Engine 51 01-01-2008 06:46 PM
What year 400 SBC Blocks Boostin1989 Engine 5 11-22-2007 05:40 AM
SBC Strokers - 350 vs 400 Blocks & Combos (not just 383 & 406) ez2cdave Engine 11 05-21-2007 09:34 PM
My sbc 400 build up, please review Guitar Charlie Engine 13 06-17-2004 08:06 AM
400 SBC Balancing and info ? Brobob Engine 8 10-31-2002 03:44 PM
