That is a small cam for a 400sbc.
You gave a lot of info but I didn't follow exactly. The heads are currently on a 350 with a 3500 stall...or? What vehicle do you have? gears? stall & trans? What is its intended purpose? |
NXS,
If you read the post your questions are already answered. Camaroguy, Was this the set up before you decided on an upgrade? |
Maybe I'm missing the point of some of this advice, but why put a high-rpm cam in a low-revving engine?
If its a stock 400 with the stock heads, you are probably looking at 8.5:1 compression so you would want a camshaft to match this. The Xe268 cam would be excellent if the 400 is completely stock. Using that 400 motor with a stock bottom end along with a 3500 stall, that motor will not last long though. It is only going to leave you appr. 1500 usable rpm from 3500-5000. Stock 400's are not good for turning rpms with the big end of the stock rod with a stock bolt being the major flaw along with the rod-stroke ratio. Stock 400's are designed for torque at a low rpm. I would go with your combination except go with a 2000-2400 rpm stall. If you can get the heads done also, it won't hurt a thing. Street 400's can easily use a 200cc intake port and stockers are around 160.
On my 400 I went with a 114o lobe sep. It helps keep your torque curve nice and flat. That is good. With a 400 the torque will already be high. Spreading it out over a larger powerband will net excellent street manners. I went with a 2,400 stall. I have a lot bigger cam in mine. I recommend a 1,800 to 2,000 stall for yours. I also kept my stock gearing. This enables me to stay within my peak torque range longer. The extra torque of the 400 will allow you to run lower numeric gearing and still get off the line easy. I have Sportsman II heads. They came stock at 200cc. My set is ported to the max. I still have more bottom end than I know what to do with. |
I also used the XE268 in my 406. It's the largest XE cam for a stock converter. It would break the tires loose with a 2.41 rear gear!
The reason I asked about the prior set-up was because that stall seemed way high. |
OK, sorry for the delay on gettig back to this topic.
I bought the car with the tranny but no motor. I put the 400 SBC in it later. The 400 SBC is completely stock. I only put headers, edlebrock Performer, and the Holley Carb. I called the guy that I bought the car from last night to verify that it is a 3500 stall, however he said it was only a 2500 stall. So, I apologize for misleading anyone it is a 2000 Stall rather than a 3500. The car will be used for Cruise In's, street playing (stop light to stop light kind of thing), and other stuff. I would like to take it down the 1/8 mile once or twice but nothing too hard. I want a great sounding classic car that will have lots of power on lauch and will cruise nicely. I looked at the heads and wrote the number off the heads down, but have not been able to find then on any database, so I will have to verify that this is the number on the heads: 3973488 Thank you for your replies on this. |
I don't know what heads you have.
A Comp 280 would be nice for you. It will give a good sound and won't be too big for the 400ci even with an average set of heads...but you really need to know more about those heads to make a proper decision. Intake runner cc Combustion Chamber cc Valve size. If they are1.94s and 160cc runners/64cc run the 280/480" if they are a 72 cc run a steel shim head gasket and the 280/480" If they are 155cc intakes runners, port them or look for new heads. |
I'll look again, maybe I wrote the number down wrong.
Most of the stock heads I have see for the 400 SBC in were 76cc heads. I'll double check today and post back. Thank you for your time helping me. |
