Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 SBC oil pan question..What quart size of pan do I need?
Old 07-25-2010, 07:25 PM
LATECH's Avatar
LATECH LATECH is online now
I agree with techinspector. At high rpm with high volume pump a lot of oil stays up in the motor so you need more capacity to draw from in the pan.A windage tray or a crank scraper is also a good idea as it helps return the oil to the pan quicker and cuts down on parasitic loss from the oil clinging to parts. ( could be considered neglegible)
