Is this 400 sbc ok to run? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2006, 08:39 PM
Last journal entry: Rusty Trunk Floor Pt. 1
I'm lookin at a 400 small blockchevy block for $500 Canadian and was wondering if you guys think it's ok to use.
Its been hot tanked, magnafluxed, and bored .30 over
It's a 2-bolt main block which i have heard is more desirable than a 4-bolt main 400 block is this true?
He said it's also more desirable because it's 509 casting, whats different about the 509 casting than other castings?, is it higher nickel content?
What i'm most worried about is the fact that it had a small crack in the lifter valley but has since been repaired, do you think that this area will be a weak spot in the future?
And also is .30 over to much for a 400 block?
and does $500 CDN sound like a good deal?
Old 08-17-2006, 09:39 PM
MI2600's Avatar
Member# 3287
How was the crack repaired? I've seen some cobbled up weld and brazing jobs. The only repair that I've seen hold was the type using pins.
If it has been "welded", I would pass.
Old 08-17-2006, 09:48 PM
well i havent seen it yet but he said it was professionally welded.
Is .30 over safe for a 400? would i run into overheating problems?
Old 08-17-2006, 09:52 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
If it were me I would pass. Its not the money. If it were free I wouldn't build it simply because all I would do when running it was worry about that crack. The words "crack" and "engine block" in the same sentence is a bad thing IMHO.
Old 08-17-2006, 10:31 PM
If it makes a difference it was a small crack.
I have no idea what to do, i'll take a look at it tommorrow and we'll see what happens.
I shoulda made a poll
max 400 sbc 6speedwagon Engine 18 02-02-2011 12:27 PM
sbc 400 81camprj Introduce Yourself 4 02-15-2007 10:25 AM
Holley 4160 carb on 400 SBC. Silver_Camaro Engine 3 05-14-2005 11:22 AM
Critique my SBC 400 Combo DTL504 Engine 24 11-30-2003 05:37 PM
67 impala run a 327,350,or 400? DeezImpala Engine 2 06-25-2002 09:05 AM
