Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 sbc powerglide trans top speed 1/4 trap
Old 01-22-2013, 08:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by savage9scorpio View Post
okay I have a 400 sbc stock bottom end. aluminum dual plane intake, 750 qjet, stock heads (for now) and a powerglide w/2.73's AND 488/510 CAM WITH 114 LSA. I haven't got the timing done completely so its still a lil off and I've been advised not 2 go WOT until I do get the timing down. but so far I love the 400's torque compared 2 the putt putt 307 I had.
the motor shifts into second around 40mph. can drop down 2 20mph while its in 2nd.
BUT MY QUESTION IS WITH A WIDE LSA WOULD THE TOP END BE MORE THAN a smaller lsa cam?
A wider LSA favors top end over bottom end, but the difference won't be huge unless the cam is a mismatch from the get-go. An article that compares various LSA in a SBC 400 (as well as open and divided plenum intakes): http://www.chevyhiperformance.com/te...t/viewall.html
Also, many cams have ground in advance when installed at the recommended ICL. This doesn't change the LSA, but tends to bolster the bottom end.
when I'm in it it feels good on the highway I'm cruising @ 72 right around 1900 rpm. this is a STREET CAR. I haven't gotten into the throttle 2 much but what should be top end speed when I do get into those big secondaries?
Wallace Racing - Automotive Calculators
