400 sbc question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2005, 05:48 PM
4doorjoe's Avatar
400 sbc question
HI guys could some one tell me if a 400 sbc 2 bolt main is a small journal or large journal thanks for your time joe
Joe sammut
Old 10-10-2005, 05:54 PM
coldknock's Avatar
All 400's had 2.65" main journals, 0.020" larger than the 350's. The rod journals are 2.100", same as the 350's.
Larry
Old 10-10-2005, 06:00 PM
4doorjoe's Avatar
400sbc question
thanks for the reply the reason i asked the question was to find out what to order for main cap bolts from arp large or small journal so it would be large journal thanks again
Joe sammut
Old 10-10-2005, 06:01 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
The rear main cap is fairly thin and weak. It is safer to use an oil pump stud instead of a bolt. If you crack the cap your screwed.
Old 10-11-2005, 12:50 AM
Yeah, bracketeer is right. Put them studs everywhere you can on a block that old.
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 07:29 PM
SBC Valve Cover Question Jag Daddy Engine 4 10-31-2003 05:03 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 09:02 PM
balance for 400 sbc gaino Engine 9 02-28-2003 06:25 PM
400 sbc Overbore nova69 Engine 4 02-04-2003 07:22 PM
