400 SBC rear main, which seal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2010, 01:09 AM
Dizturbed One's Avatar
I notice I get an "oversize" and a regular seal when looking for it, and after a little reading around found that one is for an align-honed block.
I know my truck has had rebuilt internals (bearings, rings, valve guides, oil pump that I know of) but have no idea if it was align-honed at all since I did not rebuild it, and the man that did the work is R.I.P. bless his soul.
Is there anyway to visually tell the difference once you have it all apart? I will have the transmission out of the truck also, so I can get a good look. Any help is appreciated, thanks guys.
Old 07-21-2010, 01:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Visually, you will see a different looking finish on the inside of the caps and block saddles, and the caps' bottoms will also show an indication of having been machined recently.
If you wanted to determine what the c/c measurement of the crank and cam- which would also indicate if the crank centerline had been moved by boring/honing, you could install the cam and crank then measure the overall distance of those two installed components (called "measure over shaft" or MOS) in the engine as shown below.
From HERE:
The formula is: center distance = MOS - (crank diameter/2) + (cam diameter/2).
Old 07-21-2010, 04:34 AM
BOBCRMAN@aol.com's Avatar
Edited,,,geezerbrain...
Pontiac Rear main Seal 71 c-10 Engine 2 05-21-2007 10:22 AM
351W Rear main seal... 301Customs Engine 3 04-16-2007 02:48 PM
Rear Main Seal Adapter Kits Mustangsaly Engine 6 08-07-2006 01:23 PM
Help On Chevy Rear Main Seal JimKramer Engine 9 02-07-2006 08:39 AM
2 piece rear main seal Brian Morency Engine 6 07-07-2004 11:54 AM
