#1
400 sbc stock. comp with 64 cc heads
Hello . i am looking .at putting a set of bowtie phase 2 heads on a 1975 400 sbc .they r 64 cc heads .wondering what my comp.ratio would be .also have a set of 65 327 heads .with 202 1.6 valves installed .they r 60 cc .dont no wich to go with . it will be used for drag racing .. the 400 still got lots of life in it figured why not run it till she goes .. thanks for your time ..
Register now (free) or login to remove ads |
#2
Is it further to Cleveland, or by bus? |
#5
Well i would think there is enough info there for someone who knows Chevy to figure it out ..all i am asking is for comp ration from a stock 400 sbc 1975 with 64 cc chambers .which would of had 76 cc heads stock .. or the 60 cc heads .and which would be best .for drag application . i would think the flow rates of the phase 2 would be better for upper rpm where the motor will b in most of the time .or if the other 4 cc would make that up for the extra comp . |
#7
If your stock 400 was 8.6:1 with 76cc heads then with a 64cc head the cr will be 9.65:1 and 10:1 with a 60cc head on it. Assuming the same head gasket volume is used.
| Thread Tools | Search this Thread |
| Similar Threads for: "400 sbc stock. comp with 64 cc heads" | ||||
| stock rebuild sbc 400 | eatonde | Engine | 8 | 12-07-2008 06:08 PM |
| Question on Pro Comp Heads on SBC and intake matching | y2k600f4 | Engine | 19 | 09-29-2008 05:55 AM |
| Rebuild and port old GM sbc low comp heads for blower setup | burkgul | Engine | 5 | 06-25-2008 09:58 AM |
| Pro 235 cc heads for 383 SBC | flyin99 | Engine | 1 | 03-01-2007 07:11 PM |
| Would like a stronger sbc 350 than stock heads. | StingRay69 | Engine | 6 | 11-12-2005 03:22 PM |
