Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 sbc vs 400 pontiac
Old 12-22-2006, 07:59 PM
QuenchPiston QuenchPiston is offline
Originally Posted by runn141
what i have seen with pontiac the pontiac 350 will kill a pontiac 400, i think the pontiac 350 is also a big block. correct me if im wrong
I think I have been thru this once before. Seeing how the Pontiac 350 and 400 were separated by 20 HP according to some factory ratings I can see how "you" would argue that. Consider the 350 had a 3.88 bore vs. the 400's 4.12 bore both having the same stroke of 3.75. Which one do you think will have better breathing abilities? I plan on snatching up a 350 Pontiac this summer for a T build but... if I cant find one and a 400 thru 455 is available then I guess I will have to be satisfied with that.
