400 searching
On this year 400 the passing gear is controlled by the computer.
The computer monitors the map sensor [ vacuum ] and grounds kickdown relay, for passing gear, when vacuum is low. If you hook a test light to ground and to terminal "A", of the relay,then with the engine running, nail the throttle for just a second, the test light should come on, briefly. Yours probably won't light up [ you disconnected the kickdown and trans works good ]. So if no light, with engine off, key on, disconnect the computer and ground the computer harness at terminal A7. If the light comes on, suspect a problem with the map sensor. If the light stays off, check for 12 volts at the relay, terminals D&E. If you have voltage at D&E, replace the relay. If you do not have voltage at terminal D and this is a C or K series truck, check for a misadjusted brake light switch, or bad fuse. This procedure is for a no kickdown situation. YOu can circumvent all of these diagnostic procedures and just install a kickdown switch and bypass the computer, if you like. |
| 400 cid SBC | Shades_o_Grey | Engine | 20 | 02-04-2008 12:28 PM |
| 400 - sbc | gilby246 | Engine | 4 | 10-19-2006 10:44 PM |
| Powerglide trans to 400 Chevy motor | K9sicem | Transmission - Rearend | 3 | 07-09-2006 08:43 AM |
| 383 or 400?? | KFXrider88 | Engine | 7 | 06-13-2006 05:45 AM |
| Small Block 400 | chevyelc81 | Engine | 9 | 06-18-2002 06:10 PM |
