400 small block - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 10-02-2013, 09:00 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Tony-these thread's advise might seem to the OP that I (we) want the OP to go on a spending spree.The truth of it I (we) are telling the OP short money spent twice is never cheaper. So early on in this thread I do believe I suggested to spend the $300 to $500 for a hydo roller conversion. Along with sonic checking the thin wall 400 block and finish bore size with torque plates having the pistons in the hands of the machine shop.Really,not trying to be a Bass Hat here Tony.My point is I (we) try real hard to scout ahead for OP's builds and in a the long run,are trying to save them money.
Again as I did before Tony,I wish all the best on your build,
Gary
  #77 (permalink)
Old 10-03-2013, 07:16 AM
Gary
Thanks Gary, I still dont see what is so wrong with a flat tappet cam,engines have ran good and strong with them for years especially if you do a good break in like tech1 and f'bird sent me. I am a little worried that my builder wont take the time to do all the things required to help the cam live but you have to put trust in some people some time.
  #78 (permalink)
Old 10-03-2013, 08:50 AM
vinniekq2's Avatar
another thing,the roller cams make better power.This is a reason to use one
The Following User Says Thank You to vinniekq2 For This Useful Post:
gmtony55 (10-03-2013)
  #79 (permalink)
Old 10-03-2013, 09:01 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by gmtony55 View Post
Thanks Gary, I still dont see what is so wrong with a flat tappet cam,engines have ran good and strong with them for years.
The following paragraphs are quoted from Crower Cams......
"For more than 70 years ZDDP (Zinc Dialkyl Dithio Phosphate, containing Zinc and Phosphorus) was a mainstay of motor oil, providing trouble-free engine protection. The E.P.A. has now forced most ZDDP from domestic motor oil, including diesel oils. This lack of zinc and phosphorus is most severe in the just-released 'SN' (ILSAC GF-5) rated oils.
If your engine was designed prior to the 1990s, or if you're running a modern high performance motor with a flat tappet camshaft, your non-roller lifters require ZDDP zinc oil additive to prevent metal-to-metal contact and subsequent deterioration. Newer testing, mentioned in one oil manufacturer's advertising, also attributes piston scuffing to the decreased levels of zinc and phosphorus.
Don't let metal-to-metal contact destroy your new engine a 4oz's (1 bottle) of ZDDPlus added at every 4 to 5 quart oil change provides the correct amounts of zinc and phosphorus in your oil, protecting your investment.
ZDDPlus contains the proper amount of ZDDP to give at least 0.18% zinc and 0.13% phosphorus level when a single 4 ounce bottle is added to a 5-quart oil change. This level of zinc and phosphorus is the level designed into pre-OBDII oils. Using ZDDPlus affords you total control over the choice of oil brand and viscosity, ensuring the protection of your flat tappet motor. ZDDPlus is compatible with any oil, including synthetics, and is compatible with the additive packages present in any modern-day oil. ZDDPlus does nothing more than put the exact same molecules, zinc and phosphorus, back into your motor oil, that the manufacturers were forced to take out due to EPA regulations!"
Buy it here.....
http://www.summitracing.com/parts/cro-86092
That's not the whole story though, I'm convinced that increased hydraulic intensity has something to do with it. (think Voodoo, Extreme Energy grinds)
  #80 (permalink)
Old 10-03-2013, 09:05 AM
vinniekq2's Avatar
Richard,a question re above statement.
Lets say I go on a short road trip and I develop an oil leak, what happens if I top up my oil to get to my destination and don't have the additive? How long can I drive without worrying about cam failure?
  #81 (permalink)
Old 10-03-2013, 09:10 AM
Wiki Edits: 326
Ummmm, maybe 15 or 20 feet?
I don't know Vinnie. Never have seen test results from such a situation/problem.
  #82 (permalink)
Old 10-03-2013, 09:29 AM
1Gary's Avatar
After using Brad Penn or Gibbs break-in oil and then changing the oil to the Brad Penn or Gibbs oil,I would hope as I do when purchasing oil for oil changes,you would buy a extra qt or two.
Not a big fan of additives.Like the oils that have it blended in it.
  #83 (permalink)
Old 10-03-2013, 09:32 AM
vinniekq2's Avatar
Richard,one more question;
How much money do you save over the life of an engine if you need to supplement your oil changes when using a flat tappet cam over a roller hydraulic? Never mind the power difference,idle quality and throttle response.
  #84 (permalink)
Old 10-03-2013, 09:52 AM
Wiki Edits: 326
Let's run the numbers.
We'll assume that this hot rodder changes oil each 3000 miles and includes a bottle of ZDDPlus with each change at a cost of $11.50 per 4 oz bottle and that the motor will last for 194, 217 miles before it needs a rebuild. Over the life of the motor, there will be 64 oil changes with a cost for chemicals of $736.00.
A hydraulic flat tappet cam and lifter kit will cost ~$150.00
A hydraulic roller tappet cam and lifter kit will cost ~$550.00, or $400.00 more than a flat tappet cam and lifter kit.
Conclusion: You can buy a flat tappet cam and lifters for $400.00 less than a roller tappet cam and lifters, but you will spend an additional $736.00 over the life of the motor, just to keep it alive. Net loss to the car owner for putting up with a fosdick cam: $336.00
I don't know what you guys pay for Brad Penn and other special oils that will do the job without additives, but I'm betting that you would see about the same differential of cost over an off-the-shelf oil that you can run in a roller tappet motor.
Gee, that was fun, thanks Vinnie.
The Following 2 Users Say Thank You to techinspector1 For This Useful Post:
1Gary (10-03-2013), vinniekq2 (10-03-2013)
  #85 (permalink)
Old 10-03-2013, 10:39 AM
Ok, so I see flat tappet cost as not so bad, being that it took 30 years to get that many miles on my elcamino.lol I would one day like to modernize my drive train with an LS2 or 3 set up after two more kids are graduated from college and I will have more funds to spend. If I could get 70 to 80,000 miles from this build I would be very pleased.
by the way what does "fosdick" mean?
  #86 (permalink)
Old 10-03-2013, 11:11 AM
Wiki Edits: 326
Fearless Fosdick was a character in the comic strip "Dick Tracy" by Chester Gould. Fosdick screwed up most of what he touched and was a failure, so anything that is screwed up is termed fosdick.
http://deniskitchen.com/Merchant2/me...e=bios.fosdick
  #87 (permalink)
Old 10-03-2013, 11:18 AM
vinniekq2's Avatar
maybe another question Richard,Is there 100% guarantee that if I use the additive that the flat tappet cam won't fail?
I know a complete tear down is very expensive,maybe more costs than the original build
  #88 (permalink)
Old 10-03-2013, 11:54 AM
I am scratching my head on this one..did I miss something? Is the hydrolic roller tappets giving a 100% no fail warranty?
  #89 (permalink)
Old 10-03-2013, 11:56 AM
Wiki Edits: 326
This is turning into a Burns & Allen skit.
  #90 (permalink)
Old 10-03-2013, 11:58 AM
Wiki Edits: 326
No, you didn't miss anything. Vinnie is just having fun. He dislikes flat tappet cams almost as much as I do.
400 Sm Block To 409 Cu In Small Block jollyroger040 Engine 2 10-16-2007 06:37 PM
my 400 small block zhawg Introduce Yourself 3 09-17-2007 10:46 PM
400 small block arobe06 Introduce Yourself 1 06-26-2006 08:27 PM
how can i get more hp out of my 400 small block 74firebird Engine 14 01-27-2006 03:46 PM
396 Big block v.s. 400 small block Adrenaline_Fiend Engine 13 04-12-2003 04:14 PM
