Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 400 small block compression and head gasket question
Old 07-07-2005, 09:48 PM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
Look under the piston. You may find a manufacturers name. If so you may be able to get a matching piston. If you use a piston with more or less meat. You are going to put your motor seriously out of balance. If I understand correctly. The small hole in the top of the piston designates (front). The hole goes towards the front of the motor. I would just use a Felpro 400 head gasket. With dished pistons and stock 76 cc heads a .020 head gasket isn't going to do a thing for you.
