400 Small block Fly wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2012, 10:06 AM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
Hey I recently posted about my new 400 small block chevy. It didnt come with a fly wheel. I know it needs to be a balanced fly wheel. I have one off of a newer 400 would that work? This one is a 1970-71 and I believe the flywheel I have is between 1973-80 400.
Any Help will be appreciated thanks in advance!
Ed
Old 02-26-2012, 11:59 AM
bondo's Avatar
Ayuh,... A 400 SBC Flywheel, is a 400 SBC flywheel...
They didn't make the 400 SBC long enough for there to be any variations to the flywheel...
As in, they're ALL 2pc. rear main seal motors...
Old 02-26-2012, 06:56 PM
400smb_s10's Avatar
Back Yard Junky :)
ok thanks very much
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
small block to big block swap in a 91 camaro help! Greg O Sandsten Engine 6 11-02-2010 11:02 AM
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 07:33 AM
are 1 5/8 long tubes too small for a 414 ci small block? tony350ss Engine 8 03-17-2003 11:45 AM
