We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 06-22-2005, 10:50 AM
hunter258215 hunter258215 is offline
New Member
400 small block heads and bore condition
Are factory 400 small block heads worth rebuilding (if not cracked)? I just got a 400 (long block) and I am trying to figure out if the factory heads (I didn't look at the casting number) are worth messing with. The block has the three freeze plugs on each side. What does anyone think?
What are the specs on the cylinder bore being egg shaped. What is too much eggness?
Old 06-22-2005, 11:49 AM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
All of the stock 400 heads I've seen have been 76cc. There's a lot of 882s, but there are some heavy-casting 997s and 493s. Nothing wrong with them and they might come in handy, unless you go to a dished piston, to keep the compression in the pump gas arena.
Old 06-22-2005, 12:36 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
No more than .003 outa round for best wear and ring seating. You can get away with more though. It's just not ideal.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "400 small block heads and bore condition"
the history of chevy v8's savman1 Engine 30 01-25-2008 01:02 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
400 small block re"performance"build 78 monte Engine 2 04-19-2003 07:32 PM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 07:06 AM
Compression on a 400 small block LiLEcZ40 Hotrodders' Lounge 1 06-09-2002 02:32 PM
