yes,i also think it sounds like a vac. leak.sounds like you're going to have a good light to light motor with those heads.i'd be curious to here about it when you get the problem solved.did this carb work before on the old motor?one thing you never ever want to do is start a new motor with a defective carb. but i know how yuo feel at this point.we've all been there.try spraying the wd-40 and see what happens and come back if need be.good luck
also i did make the mistake of totally rebuilding a carb to start this motor just cause the carb is fresh and i was confident with my carb tuning skills. the only reason i tore apart the 450 was because i thought it would be too small but it prob would have been fine for break in and tuning. the 600 is set back to just about stock and it is clean and nothing leaks. i will try the carb cleaner/wd 40 method and wil play with idle mixture screws. its definitely possible that its a carb base gasket leak. my friend says that he has 20-25 initial timing in his 357 with the same cam and he says the motor loves it. i thought this was high but i guess i could be wrong. any other suggestions?
Try this.
Unplug your vac advance and plug it at the carb. Set your timing to 12 degress advance Hookup your vac advance to the "MANIFOLD" port on the carb. Reset your idle and mixture screws |
If you have the idle speed screw in that far then the carb is idling the main circuit (blades open past the transition slots). You either need to get a bigger carb (bigger throttle blades) or you need to drill some holes in the front throttle blades to let air in without opening up the throttle blades past the transition slots. A 0.100" hole in each front blade should do it.
Also a 268 cam should have about 15 to 20 degree initial ignition timing. Try using paragraphs next time. Your post is very hard to read. |
the vacuum advance is hooked up to manifold vacuum and the other port on the metering block is plugged. as for the timing i will prob try bumping it ahead to 15-20 as you guys recommend. i thought about modifying the carb or getting a bigger one because i thought the same thing that the carb is idling on the main metering circuit and i need to let more air by.
i dont know the affect changing the timing will have though. i only have the idle speed screw up this high because it needs it to run because the motor will not idle which still leads me to believe i have a vacuum leak. i still havent got any time to start up the car and run it again though so i havent gotten any further. by drilling the throttle blades i will be able to keep the idle speed screw turned in farther but not draw as much fuel correct? i will get back to you guys as soon as i get to run the car again. thanks for all the help so far |
You mention that your vac. adv. is already connected to the manifold port, which is good. Do you know the specs on the can you are using? In order to make the most of the manifold vacuum setup, I had to use Crane Cams' adjustable vacuum advance kit (which also includes a vac. adv. limiting plate that is VERY useful).
The goal here is to get the vac. can set to peg out below the least amount of vacuum (which is at idle in gear of course). I set my 406 to 18 initial and with the vac. advance it idles with about 33 degrees total. The motor runs great like that (and the throttle blades are almost entirely shut). My 355 was the same - Crane Cams adjustable kit, 15 initial, for a total of 32 at idle. The adjusting plate that comes with the kit is nice because you can limit the amount of vac. adv. that you get, and then you use the screw in the vac. port to adjust the "Hg that allow it to open. All this will help your fuel economy too. I've found a lot better mileage after setting the vac. adv. up well. Although both motors still run a little rich at idle- but never load up or foul plugs. Another thing: I drilled holes in the 670 HOlley for the 355 - it actually didn't seem to do that much for me. I had better luck getting the idle correct with the vac. adv., but the holes don't seem to have hurt me. The 406 is much hotter, only has a 750 holley, and I cracked the secondaries just a little. Have the primaries almost totally shut here, too, made possible by vac. adv. Good luck! |
| 350 or 400 Small block | Larry Day | Hotrodding Basics | 9 | 04-09-2009 09:12 PM |
| 400 small block compression | 19nova72 | Engine | 2 | 07-20-2005 02:29 PM |
| 400 Small Block Questions | Dark Jester | Engine | 3 | 07-08-2005 11:02 PM |
| 396 Big block v.s. 400 small block | Adrenaline_Fiend | Engine | 13 | 04-12-2003 04:14 PM |
| 400 small block chevy | bo 1972 | Engine | 1 | 12-24-2002 07:03 AM |
