-   -   400 small block swap trans torque converter (http://www.hotrodders.com/forum/400-small-block-swap-trans-torque-converter-227096.html)
savage9scorpio 12-12-2012 05:59 AM
I have a rebuilt 400 small block. the problem I think I am about to run inti is trying to put this motor on the powerglide trans that I have. I believe the flexplate may b different as well as if the bellhousing will match or if I need to change it. can some help out with some info on this swap and matching to this trans.
cobalt327 12-12-2012 08:16 PM
The Powerglide will fit the SBC 400 engine you have. The flexplate's torque converter bolt pattern may or may not work w/the Powerglide torque converter, so check it to see. The torque converter has to be for the Powerglide unless the PG has an aftermarket TH350/TH400 spline input installed.
savage9scorpio 12-19-2012 07:35 PM
thts what the dude I spoke wit @ Jegs mentioned. something along those lines. what does tht mean about the spline shaft and 350. can I have the transmission shop down the building from my job do tht somehow so I could use a normal torque converter. excuse me if I sound weird about the subject but I know extremly little about this part here.
cobalt327 12-20-2012 08:46 AM
It's doubtful the input shaft has been changed to a TH350 spline, that's not a routine thing to do.
You'll need to look at the input shaft to see if it's a PG or what, but like I said, most likely it's a PG input that will use a PG torque converter. The PG splines are a lot coarser than the TH350 splines- IIRC 17 splines for the PG and 30 for the TH350.
That said, are you sure you want to use a PG in the first place? They're not a good match for a normal-to-heavy vehicle. The torque of the 400 will help some, but they're just not a good tranny for most applications IMO.
savage9scorpio 12-20-2012 09:49 AM
okay so I found a powerglide tc off cl thts lightly used for $ 75. the only thing is. will this converter with and estimated 2500-2800 stall be enough for the 400? the car is light maybe right around 3300 with me in it. the powerglide has been in the car since I purchased it. and a powerglide is cool with me. when I go 2 the track and run grudge matches I like the consistency of the one gear shift. its a streetcar/highway cruiser tht sees about 40 roundtrip miles back n forth 2 work daily
what happens if there isn't enough stall?
cobalt327 12-20-2012 10:04 PM
Well, more torque, more weight, higher gear ratio = more stall from the same converter and vice versa.
In your case bigger engine w/torque = more stall but less weight = less stall. So maybe they'll cancel each other out. lol But there's no way I could say from here if the 25-2800 rpm stall estimate you got will be right without trying it first to see.
BTW, most companies rate their TC behind a mild small block unless otherwise noted. The same tc behind a bigger torquier engine will stall higher.
savage9scorpio 12-20-2012 10:11 PM
thanks 4 the heads up on tht.
cobalt327 12-20-2012 10:14 PM
Now obviously that doesn't hold true w/small diameter high stall units. This is for the street TC range, =/> 11" stuff mainly.
