400 smallblock desktop dyno please
hey guys, im marshall, long time reader first time poster, im in new zealand so may posts and replies may be delayed with the time difference. ill post a proper introduction in the introduction section with pics of my car and work done but at the mo im just wondering whos running a similar setup to this and what sorta power itd produce...maybe some desktop dyno figures or real world figures from similar setups, just curious as to what my engine might be putting out, its nothing fancy at the mo
400 chev bored .030 stock stroke edelbrock 750 vac sec carb edelbrock performer manifold pro topline torker heads, (1.94 valve, 167cc, 76cc combustion chambers, de-burred and bowl blend work, exhaust ports polished and both sides port matched but not gasket matched) pistons are stock dished crane 272 energizer cam hydraulic flat tappet block huggers into true twin 2 1/4" exhaust no crossover pipe pistons are down the bores about 060 and im thinking around 8.5 comp ratio t700 trans with transgo shift and junior kits and 3-4 clutch update kit stock torque converter 3.55 limited slip salisbury rear end, 26.5" tyres car is a 52 chevy 4 door runs at 2000rpm at 60mph in overdrive and about 1500rpm at 30 mph in 3rd its just a real super mild setup, was aiming for a mid range torquey super reliable street car with the torque band right around about 2500rpm where the revs would be on the open road and when i chop it down to overtake, i thought thatd keep manifold vacuum high and be good for open road economy, from research around the web i thought it might be quite a complimentary setup. let me know if i need more information cheers heaps guys |
cam is 272 duration, 216@.05, 110 seperation, .454 lift by the way
I would guess 360hp/450ftlbs.
I think long tube headers and 2-1/2 exhaust would help make more power. I think about 25hp/25ftlbs more. how does your ignition timing curve look? initial, total mechanical, vacuum advance, ported or manifold vacuum advance? read this. http://www.corvette-restoration.com/.../Timing101.pdf |
hey, yea thanks heaps for that. yea the exhaust is a bit of a sore point how i got ripped off on it..dont think ill go into it at the mo as youd haveto see the car haha. i started makin some tri-y headers for it but being i kept the stock front end around the steering box and drag link, and being RHD theres absolutely no room for them aye, theres barely enough room for the block huggers once they were modified. i told the exhaust shop theyre the experts and to put whatever size tube woulda been good for torque and thats what they done....so for 2grand ill just haveto deal with it and go somewhere else next time haha
havent really sorted it since i put the new heads on, ignition timings one of my fave things to read about here haha but i aint seen that atrticle! looks real good, easy to read, explained well, im gonna print it right now and go have a play today, let you know how i get on
haha, bent a pushrod last weekend, just after i had enough time to set the timing to 12* initial, i see thats apparently what cams with my duration a 50 thou like so thought id start there first. yea some of the pushrod guide holes were slightly oval, iv sorted it now with guideplates but have another problem, fuel delivery problems, lack of pressure to the carb and the bowls arent filling, ill start a new thread for this one though
Last edited by 52chevkiwi; 07-23-2011 at 04:46 PM. Reason: bit more info, someone might be abl to help without me starting another thread |
| desktop dyno a 350 please. | 84 Monte Carlo | Engine | 15 | 05-07-2008 04:58 PM |
| Anybody with a desktop dyno | 65Chevelle327 | Engine | 5 | 03-07-2008 09:17 AM |
| plz run on desktop dyno PLEASE! | dawg | Engine | 11 | 11-09-2007 06:46 PM |
| desktop dyno | HalfOunce | Engine | 2 | 04-23-2007 01:28 PM |
| Desktop Dyno my 406 Please | forrest | Engine | 3 | 03-05-2006 02:27 PM |
