400 turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2006, 05:27 PM
Learn It Build It Race It
400 turbo
Ok so i am rebuilding a 400 turbo, i got it taken apart and noticed the direct clutch hub has what appears to be wear on the back(or inside when assembled). I dont know if it should be flat across or has a recess. it is wore about .027 in a perfect circle. So basically does it need to be replaced? I have uploaded some pics of the direct clutch hub.
ID:	13418   Click image for larger version
Old 07-16-2006, 06:15 PM
jakeshoe's Avatar
It should be flat.
That is the forward clutch pressure plate.
I would find another one, that one is probably too worn to re-surface and re-use.
Old 07-26-2006, 11:01 PM
yeah you were right it is supposed to be flat across i found one at TransStar for 35 dollars!!
Choose Pontiac 400 or 455? & Turbo Questions TheMonkey Engine 33 08-12-2009 12:01 AM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
Turbo 400 yoke question...? Bumpstick Transmission - Rearend 8 12-25-2005 03:41 PM
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 04:46 PM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 09:25 PM
