400 turbo short shaft transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2005, 10:50 PM
I'm a beginner and I've got a beginners question. I'm putting a 400 turbo short shaft transmission in a 68 Firebird and I'm not sure how to attach the cooling lines to the radiator. Which cooling line is the sending line and which is the receiving line? Does the sending line attach to the top of the radiator or the bottom?
Old 07-27-2005, 12:26 AM
The upper line sends fluid from the cooler back to the transmission. It's the upper line at both ends.
400 turbo short vs. long ravenswood1955 Transmission - Rearend 1 10-22-2003 05:24 PM
400 turbo to 350 turbo problems mikeweyman Transmission - Rearend 2 04-02-2003 06:58 PM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 02:53 PM
g.m. turbo 400 smuhammad Transmission - Rearend 2 01-04-2003 03:16 PM
is my drive shaft too short? crebo Transmission - Rearend 2 08-19-2002 03:39 PM
