400 turbo short vs. long - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2003, 03:56 PM
New Member
as 400 short shafts are becoming harder to get, what are the pros and cons to running a long shaft in a performance car.
example, a 3klb car with a 4.56 with a 500 plus hp engine?
Old 10-22-2003, 04:24 PM
NONE..............either way..........
They are the same except for the tail housing and shaft.
I have a 400 Long in my Deuce...........
The drive shaft is 4.5 inches shorter than IF I had a short 400.
For me the 400 Long shaft WAS a advantage because a stock 88 Corvette aluminum drive shaft would fit with NO modifications.
Saved me $$$ and weight.
Total weight and unsprung weight .
