400 turbo trans. rear seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2014, 01:40 PM
I am going to replace my rear seal on my transmission, the shaft going in to the transmission is scored. can I sand down this shaft or will this cause more leakage?
Old 05-06-2014, 04:57 PM
Burnt out transmission tech.
Can you show what the shaft looks like?
If it is bad the bushing should be replaced as well.
400 turbo trans Tina Sweitzer Transmission - Rearend 1 12-31-2011 01:53 AM
400 turbo trans HRM13 Transmission - Rearend 2 03-27-2011 04:21 AM
SBC 400 Rear main Vs Rear Oil Pan Seal afsog Engine 12 02-12-2010 05:56 PM
turbo 350 rear seal leak mochine40 Transmission - Rearend 2 09-21-2006 01:52 PM
GM Turbo 400 trans front seal housing question Gary Shugart Introduce Yourself 1 01-13-2005 03:56 PM
