400 turbo transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2007, 06:33 PM
I am new at this so bare with me. I have a 86 k10 truck that I am rebuilding.
I bought it with no motor and with a 400 turbo transmission. It has 2.73 gearing in the axles, my question is does the transmission gearing affect the gearing I should put in the rear end?
I have been told that 2.73 gearing is not to good for a 4x4. I was going to put 4.11 because of the size wheel and tire i am going to put on.
Any help would be great.
Old 02-11-2007, 06:42 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
A T350 and T400 as well as any of the four speed manual transmissions available at the time all have 1:1 final drive ratios so they won't have any effect. However, a T350 does have a slightly lower 1st and 2nd gear than the T400 does. The T350 has a 2.52 first, 1.52 second and 1:1 third whereas a T400s gearing is 2.48, 1.48, 1:1. The SM465 four speed is 6.55, 3.58, 1.70 and 1:1.
What size tire and engine are you planning on running?
Old 02-11-2007, 07:15 PM
DeathRattle's Avatar
Some Punk Kid
What will the usage be? All four wheeling or city.
Old 02-11-2007, 08:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF the truck is setup for a t-400 trans to the transfer case , you will need to use the t-400. No other trans simply "bolts in" ... there are shaft size differences from t-400 to a t-350.
The gear ratio difference from a t-400 to a t-350 is not something to worry about...... both trans are 1-1 in 3rd gear as posted earlier.
a 4.10 gear would be better if a large diameter tire is use on the truck.
Old 02-11-2007, 08:36 PM
Blazin72's Avatar
Wiki Edits: 19
My question is this, did a previous owner install a T400 in it? Otherwise I thought half ton pickups came with the T350?
Old 02-12-2007, 07:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Actually with a 1986 year as posted..... there is a good chance it was a 700r4 trans in it.
Mayb a conversion to a t-400 trans with a special output shaft in the t-400 and an adapter?
400 turbo transmission? kongmen Transmission - Rearend 2 07-18-2005 12:14 AM
Turbo Hydramatic Transmission 68novafan Transmission - Rearend 1 03-20-2005 08:48 PM
700r or turbo 400 yosimdisam Engine 5 02-13-2005 11:02 PM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 08:25 PM
Turbo 400 Sandman Transmission - Rearend 2 05-27-2002 02:05 AM
