400cid heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2007, 11:55 AM
400cid heads
Can any one tell me if there is any difference in the heads from a small block 400 GM and a 350 cid GM, I know about the cooling passage, but what about performance? Thanks bob-cat.
Old 02-14-2007, 12:06 PM
nitro_baller4692's Avatar
floppers forever
what is the casting #
Old 02-14-2007, 12:14 PM
casting# is 3998991 I dont think they are what I am being told. Thanks
Old 02-14-2007, 12:41 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
All 400 heads have additional cooling holes because the 400 is a siameezed cylinder block. Heads can easily be drilled to fit a 400. Put a 400 gasket on them and drill the missing holes.
Old 02-14-2007, 12:45 PM
MI2600's Avatar
Member# 3287
All the stock, from the factory, 400 Chevy heads I've seen were 76cc. The Chevy 350 could have just about any chamber. The heads are interchangeable, with the exception of the 400 block needing the steam holes. You can use 400 heads on any other SBC because the steam holes become irrelevant.
Old 02-14-2007, 12:52 PM
techinspector1's Avatar
Wiki Edits: 326
Here's some info. Maybe will help......
http://www.purplesagetradingpost.com...ml#GM%20%20441
http://racingfeed.com/downloads/chevy_flow_data.pdf
Old 02-14-2007, 01:42 PM
floppers forever
no there not,that number is a 1972-1973 307/350 75cc cumbustion chamber.
www.mortec.com
Old 02-14-2007, 01:53 PM
Thanks nitro. Is there any easy way to find out what came on that truck in 1976? Knowing the numbers used on the 400 heads would even help.
Old 02-14-2007, 02:05 PM
floppers forever
333882 were 1974-1980
462624 were 1975-1986
468642 were 1976- up
all have 76cc chambers
the 462624 came in different valve sizes 1.72/1.5
1.94/1.5
2.02/1.6
hope this helps
Old 02-14-2007, 02:20 PM
fast68's Avatar
likes chevy trucks & boobies
what truck in 1976
what is the vin code ?
its not hard to find out
i can look it up if i have the engine vin code digit off it
my 77 K-10 pickup is vin code R
LF4 400 175hp 4bbl
Old 02-14-2007, 02:41 PM
1976 GMC 2500 vin # TKU2461520517
Thanks a bunch guys your a great help.
Old 02-15-2007, 12:03 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Did Chevy ever build a hi-power 400 cid v8? Or is it supposed to be a "performance" smog era engine? -Matt
Old 02-15-2007, 01:40 AM
No, just a torquer in heavy cars/trucks. Most people shunned it through the mid 80s, but now there are much larger small blocks....... the more things change...
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 10:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
